Hi everyone. First off, browsed this site several times for some very useful information - great source. First time posting I believe.
Have a problem. So because I was a moron and was completely not paying attention, I accidentally poured steering fluid into the brake reservoir - at least I think.Hard lesson learned but now I need to change out the calipers and master brake cylinder before my brakes stop working completely. Rebuilt calipers run about 35 apiece and a new master runs about 80 so I'm hoping my lesson learned won't be that costly. I have a couple of questions to make sure I completely fix the problem.
1. To begin with, is the master that hard to replace? Calipers shouldn't be a problem as I've done that before.
2. I need to flush all the lines. Is the easiest/best way just to open all the bleeders and let everything gravity drain out? Once all drained, would it be wise to throw down some brake cleaner to make sure all the power steering fluid is out? If so, should I then run some brake fluid through the lines to make sure all the brake cleaner is out?
3. What else am I missing that I'll need to be aware of/replace????
Thanks for your help in advance!!
edit: it's an 03 GT N/A if it matters.
