Thread: My car is FU**** WTF? 48 Codes
Results 1 to 20 of 24
  1. #1 My car is FU**** WTF? 48 Codes
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Ok short version.
    ABS light would come on at random. Replaced hub it fixed it for a sort time. But it started to kick the light on at 15mph and one of the front brakes would start dragging.
    Removed hub put old hub back on(now missing abs wire) of course abs light was on but brake light would be on too, restart car and brake light would go away. But non of the brakes started to drag. Left it like this for few months. Got a different hub and first 30 min of driving all was great. Turned car off went into a store came back out and started and boom abs light and a brake was dragging. Restarted car and was fine until i hit a bump abs light. Tried to reset system several times and nothing light would remain on and a brake would start to drag.
    Took car to friends hows to get the body codes scanned. Left his house and what do you know. Works fine.
    Now is going on with my car with all these codes?
    [PCM] P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency (Old) (History) (Immature)
    [PCM] P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage (SES) (Old) (History) (Current) (Immature)
    [PCM] P0332 - Knock Sensor 2 Circuit Low Input (Bank 2) (Old) (History) (Current) (Immature)
    [PCM] P0706 - Trans Range Switch Performance (History) (Immature)
    [PCM] P1111 - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage (Old) (History) (Current) (Immature)
    [PCM] P1573 - PCM/EBTCM Serial Data Circuit (History) (Immature)
    [PCM] P1626 - Theft Deterrent Fuel Enable Signal Not Received (History) (Immature)
    [PCM] P1652 - Powertrain Induced Chassis Pitch Output Circuit (History) (Immature)
    [PCM] P1653 - Oil Level Lamp Control Circuit (History) (Immature)
    [PCM] P1662 - Cruise Lamp Control Circuit (History) (Immature)
    [PCM] P1663 - Oil Life Lamp Control Circuit (History) (Immature)
    [PCM] P1672 - Low Engine Oil Level Lamp Control Circuit (Pending) (History) (Current) (Immature)
    [PCM] P1673 - Engine Hot Lamp Control Circuit (History) (Immature)
    [Brake] C1222 - RF Wheel Speed Sensor Input Signal is 0 (History)
    [Brake] C1223 - LR Wheel Speed Sensor Input Signal is 0 (History)
    [Brake] C1225 - LF Excessive Wheel Speed Variation (History)
    [Brake] C1226 - RF Excessive Wheel Speed Variation (History)
    [Brake] C1236 - Low System Supply Voltage (History)
    [Brake] C1233 - RF Wheel Speed Circuit Open or Shorted (History)
    [Brake] C1232 - LF Wheel Speed Circuit Open or Shorted (History)
    [Brake] U1300 - Class 2 Short to Ground (History)
    [Brake] C1265 - LR Inlet Valve Solenoid Malfunction (History)
    [Brake] C1287 - Steering Sensor Rate Malfunction (History)
    [Brake] C1286 - Steering Sensor Bias Malfunction (History)
    [Brake] C1294 - Brake Lamp Switch Circuit Always Active (History)
    [Brake] C1293 - Code C1291 Set in Previous Ignition Cycle (History)
    [Brake] C1292 - (History)
    [Brake] C1291 - Open Brake Lamp Switch Contacts During Deceleration (History)
    [Brake] C1315 - (History)
    [Brake] C1357 - (History)
    [Brake] C1356 - (History)
    [Brake] C1362 - (History)
    [Brake] C1361 - (History)
    [Brake] U1016 - Loss of Class 2 Communication with VCM (History)
    [Unknown] U1064 - Loss of Communications with DIM (History) (Immature)
    [Unknown] B0823 - (History) (Immature)
    [Unknown] B2453 - (History) (Immature)
    [Unknown] B0828 - (History) (Immature)
    [Unknown] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
    [Unknown] B2806 - (History) (Immature)
    [Unknown] B2739 - (History) (Immature)
    [Unknown] B0608 - (History) (Immature)
    [HUD] U1040 - Loss of Class 2 Communications with ABS (History) (Immature)
    [HVAC] B0367 - (History) (Current) (Immature)
    [HVAC] B0363 - (History) (Current) (Immature)
    [HVAC] B0441 - (History) (Current) (Immature)
    [HVAC] B0446 - (History) (Current) (Immature)
    [HVAC] B0361 - (History) (Immature)
    [HVAC] B0365 - (History) (Immature)
    for the oil lamps? i know work because they work when the car is started. But they have never been on out side of the system self test.
    I can explain the hvac as my temp actuators are dead. Out side of that i have no clue. There are no blown fuses.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  2. #2 Re: My car is FU**** WTF? 48 Codes
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    Wow! Never seen that b4. Bad pcm maybe.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: My car is FU**** WTF? 48 Codes
    Apr 2009
    Wausau, Wisconsin
    LOLOLOLOL!
    Sorry man but that is funny... idk why but it is.
  4. #4 Re: My car is FU**** WTF? 48 Codes
    Tulsa, Ok
    This has to have something to do with my 12-13 mpg
    98' GS - Sold
  5. #5 Re: My car is FU**** WTF? 48 Codes
    Just maybe...
  6. #6 Re: My car is FU**** WTF? 48 Codes
    Charles City, IA
    Probably a ground somewhere.
    SMGPFC Two Nipple General
  7. #7 Re: My car is FU**** WTF? 48 Codes
    memphis
    For Sale.....
  8. #8 Re: My car is FU**** WTF? 48 Codes
    Ohio
    Quote Originally Posted by Stunt0Rider View Post
    LOLOLOLOL!
    ^ You sir are an A$$!
    Back on topic. sounds like a computer or electrical problem of some nature. good luck
    00 GTP demodded and forsale
  9. #9 Re: My car is FU**** WTF? 48 Codes
    GEORGIA
    I could be wrong but i say computer. Fried somehow.
  10. #10 Re: My car is FU**** WTF? 48 Codes
    Tulsa, Ok
    Im looking for the stocker pcm now.
    PS found it. I will install it tomorrow.
    98' GS - Sold
  11. #11 Re: My car is FU**** WTF? 48 Codes
    Charles City, IA
    Quote Originally Posted by Toofastgs View Post
    Check the connections at the pcm see if they are corroded or loose.
  12. #12 Re: My car is FU**** WTF? 48 Codes
    Apr 2009
    stockton ca
    Ive never seen that many codes pop at once thats insane but grounds or pcm are the only things that could cause it
    A dealership would have a feildday with that lol
  13. #13 Re: My car is FU**** WTF? 48 Codes
    Tulsa, Ok
    Well i swapped out pcm got ride of the current ses light. But still having abs issues. I test it out the light comes one after i start moving from a panic stop( then a brake starts to drag) If i sit there the light does not come on. Now every time i start the car it sits there for 5 seconds just cranking. Normally it only does that once for when you first start it.
    Ugh!
    Honestly i would love to torch this car but i cant since it is my only ride. Hell i already need a new fender for taking a sledge hammer to it(stress relief)
    I need to get this issue fixed before it starts to get slick out. The car does not lock up the brakes at the same time as my previous cars with out abs did, so this can easily send me into a slide.
    98' GS - Sold
  14. #14 Re: My car is FU**** WTF? 48 Codes
    Jan 1970
    Maquoketa, Iowa
    Check to make sure you haven't melted any wires/harness wires. Probably change out the BCM also.
  15. #15 Re: My car is FU**** WTF? 48 Codes
    Ocala, FL
    Quote Originally Posted by wickedintent79 View Post
    Some of them want $100 just to erase a code.. he'd be out 5 grand!
  16. #16 Re: My car is FU**** WTF? 48 Codes
    Donating Users
    central ohio
    he hit a bump and trouble started, you found your problem, bad ground or corroded conn some where.
  17. #17 Re: My car is FU**** WTF? 48 Codes
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Chris you have some serious bad luck with vehicles... Hope you get it sorted out.
  18. #18 Re: My car is FU**** WTF? 48 Codes
    SE Level Member TEBO's Avatar
    Apr 2009
    Check your grounds. My dad and i have seen some weird crap with bad grounds!
    *sig too tall, 200 px or less*
    98 Grand Prix GT(green)
    In trunk computer
  19. #19 Re: My car is FU**** WTF? 48 Codes
    Tulsa, Ok
    Again for right now i swapped out the pcm with the stocker and no codes.
    Still have the weirdest abs issue
    98' GS - Sold
  20. #20 Re: My car is FU**** WTF? 48 Codes
    May 2008
    McHenry IL
    LOL lacrosse but yeah man i just graduated from obdII diagnostics class id say since u changed out the pcms and u still have abs codes you might just have a common bad ground i believe under the front plastic shrouding " between the core support and the front bumper there are a few groudns there that control that stuff it can get fishy check and advise
  1. Codes for A/C
    By ASTROALCHER in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 12:49 PM
  2. how to get codes
    By bowtechguy in forum General Tech Discussion
    Last Post: 04-16-2009, 05:19 PM
  3. codes codes codes
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2009, 09:15 PM
  4. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
  5. I got some codes
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2008, 07:41 AM
