Thread: GTP Knocking Sound. Any Ideas?
Results 1 to 5 of 5
  1. #1 GTP Knocking Sound. Any Ideas?
    Indiana
    Cant figure out this knocking noise. I have a 2002 gtp. I have ssac headers, 3 inch downpipe, no cat, no res, stock mufflers, 180* tstat, k&n cai, zzp stage 1 throttle body, dhp 1.0 pcm, 3.4" pulley, fuel pump re wire, alt re wire. I have a knocking noise from 2500 rpms to about 4000 rpms. it doesnt do it after 4000 rpms and it doesnt do it before 2500 rpms. i cant figure out what it is. any ideas on what it is or any suggestions how to fix it? please help
  2. #2 Re: GTP Knocking Sound. Any Ideas?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    where does the sound seem 2 be coming from?
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: GTP Knocking Sound. Any Ideas?
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to CORRECT section
  4. #4 Re: GTP Knocking Sound. Any Ideas?
    Only in park? Flex plate. If not...could be something internal.
  5. #5 Re: GTP Knocking Sound. Any Ideas?
    Indiana
    I cant tell if its coming from the front or back. What could it be in front? what could it be in back? It doesn't do it in park. Only in drive. Its most noticeable in drive. Thanks for replies
  1. 04 GTP....Supercharger Knocking?? Why?
    By hazards280 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 12:29 AM
  2. Engine Rumbling/Knocking, HELP Please :)
    By crusinchub in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2009, 06:46 PM
  3. Poly mounts...knocking sound
    Last Post: 05-16-2009, 03:48 PM
  4. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
  5. engine knocking
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 01:50 PM
