Thread: "CLUNK" suspension noise when i step on it?
Results 1 to 19 of 19
  1. #1 "CLUNK" suspension noise when i step on it?
    South Dakota
    Alright i have been having this problem for a month or two. When i am driving and put it to the floor there is one loud clunk as the front end picks up. If i roll on the gas there are multiple clunks in quick succession. I just replaced the struts hoping it would be the problem but it didnt fix it. Anyone know what this might be?
  2. #2 Re: "CLUNK" suspension noise when i step on it?
  3. #3 Re: "CLUNK" suspension noise when i step on it?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    did u also replace the strut bearings
  4. #4 Re: "CLUNK" suspension noise when i step on it?
    South Dakota
    need to know more. mod history?
    when i am moving at a constant speed it doesnt happen, so bumps in the road arent whats causing this. it will sometimes do it when i back out of the driveway with my wheel cranked. and i have a 3.5 pulley and supporting mods
  5. #5 Re: "CLUNK" suspension noise when i step on it?
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    any exhaust mods? mine was hitting initially til i figured out what i did wrong on the install
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  6. #6 Re: "CLUNK" suspension noise when i step on it?
    South Dakota
    Quote Originally Posted by mikesarebetter View Post
    yea i have powerlog, 3" dp, and higher flow mufflers
  7. #7 Re: "CLUNK" suspension noise when i step on it?
    Spearfish, sd
    higher flow mufflers.. haha.. we won't get into that. but i would check that.. when i installed my headers my downpipe was hitting the floor when i would gun it. ended up just flipin stock motor mounts and that was enough to keep it from hitting.. but that's on 2003.. don't know how much differnet the newer ones are. but if flippin mounts is as easy for yours i'd try that.. unless your positive it's not the exhaust
  8. #8 Re: "CLUNK" suspension noise when i step on it?
    South Dakota
    well l've had this exhaust for quite a while. and this clunk doesnt sound like it could be that. thanks
  9. #9 Re: "CLUNK" suspension noise when i step on it?
    SE Level Member GINOSGTP's Avatar
    Feb 2009
    Ontario Canada
    Ive got a 2004GTP and it does the same thing....i was told that it could be a bad motor mount,,,,weather or not thats true i dont know but it does make sence
  10. #10 Re: "CLUNK" suspension noise when i step on it?
    South Dakota
    Quote Originally Posted by GINOSGTP View Post
    that does make some sense thanks. I might just take it in and see if they find whatever it is
  11. #11 Re: "CLUNK" suspension noise when i step on it?
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Profile says Dogbones. Assuming you flipped 'em. Did the rubber tear out??
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  12. #12 Re: "CLUNK" suspension noise when i step on it?
    Guam
    Check your lower control arm bushings, the larger one.
    If the larger one separates from the metal can, it hits the craddle and clunks at times.
  13. #13 Re: "CLUNK" suspension noise when i step on it?
    South Dakota
    Quote Originally Posted by Gregorius View Post
    no actually they are just shorter
  14. #14 Re: "CLUNK" suspension noise when i step on it?
    Serena, IL
    Check the vertical bushing in the lower control arm. How many miles on the car? I'd put my money on that.
  15. #15 Re: "CLUNK" suspension noise when i step on it?
    South Dakota
    Quote Originally Posted by xringshooter7 View Post
    124k
  16. #16 Re: "CLUNK" suspension noise when i step on it?
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    yeah man, check the dogbone mounts and the other motor mounts. i got the poly mounts for the dogbones and it greatly reduces engine tilting. now my d/p from my headers are hitting floorboard, fun!
  17. #17 Re: "CLUNK" suspension noise when i step on it?
    South Dakota
    it turned out to be a "loose radius bar" that what the shop i took it to said (this was a couple months back btw. i tightened it and now its just fine. This may help someone out in the future
    3.4 pulley, Wizaired intake, 3" catless dp, 160* tstat, Shortened dogbones, Ported manifolds, aftermarket mufflers, 103's, zzp pcm
  18. #18 Re: "CLUNK" suspension noise when i step on it?
    Roseville, Michigan
    I have a bad clunk when I put mine in reverse and do a quick back up but thats the only time it happens. I think a bad motor mount but Id like to know where this radius bar might be.
  19. #19 Re: "CLUNK" suspension noise when i step on it?
    South Dakota
    Quote Originally Posted by greengt View Post
    Thats funny that you would ask about this now. My car has recently developed a clunk when it is put into reverse, it sounds like a mount to me too. So since my radius bar is tight i know this is not it. The radius bar is more of a clunk that happend when i turned the wheel or accelerated heavily never happend in reverse. Let me know if you figure it out
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
  3. "Clunk" on initial rolloff
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2008, 05:07 PM
  4. SC "tapping" noise... HELP!!
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2008, 05:30 PM
