Thread: blow out
Results 1 to 20 of 24
  1. #1 blow out
    Joliet, IL
    so i officially blew out the 3 bolt flange gasket on my pacesetters....should i get a vband to replace that joke of a flange or get it welded like bluegtp91?
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  2. #2 Re: blow out
    Banned - Busted For Scamming
    Feb 2009
    pacesetters lol
  3. #3 Re: blow out
    Norristown, PA
    get it welded
  4. #4 Re: blow out
    Then wtf was the point of the 9,000 PM's about doing it?
    You haven't done it yet? Cmon man.
  5. #5 Re: blow out
    Feb 2009
  6. #6 Re: blow out
    Donating Users blowfishRus6's Avatar
    g.a.
    how do you blow that part out???? put some thread lock on the bolts...
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: blow out
    Outer Space
    The top bolt is near impossible to get tightened real well. I am pulling my welded pacesetters off in the next week or too. I have a new flex to weld in, and was thinking about a v-band clamp as well.
    I used like 3 paper collector gaskets and coated the poo outta them with copper RTV.
    02 GTP 13.6 @ 100mph - SOLD
  8. #8 Re: blow out
    FWIW...O'Rielly's sells a copper header gasket that fits perfectly...in the 3 bolt flange.
  9. #9 Re: blow out
    Feb 2009
    Still doesnt solve the clearance issue. Get the product in the link and take it to a welding shop and have them weld that in.
  10. #10 Re: blow out
    Joliet, IL
    i have the y, RH and crossover welded but not the dp...
    00 Silvermist GTP
  11. #11 Re: blow out
    g.a.
    this. its what i have and works really well.
    for the top bolt i just on hooked the dog bones and pushed the motor backwards. made the top bolt pretty easy to get to.
    its slow.
  12. #12 Re: blow out
    Joliet, IL
    i think ill just go v-band..... damn you think that v-band requires me pulling everything out or can it be done on the car....
    00 Silvermist GTP
  13. #13 Re: blow out
    g.a.
    not quite sure how the v band works, would you have to grind off the 3 bolt flange??
    its slow.
  14. #14 Re: blow out
    Jersey
    **** pacesetters...I broke one of those v-band clamps on the d.p today
    surprisingly autozone carries a flange gasket that lines up perfectly with the pace****ter d/p for $8 and change.
    16' wrx sti- stock
  15. #15 Re: blow out
    g.a.
    the mr gaskets one??? i wouldent not use them i blew one out in a week. the cooper is alot better.
    all it is, is a normal 3in 3 bolt gasket. there pretty universial.
    its slow.
  16. #16 Re: blow out
    ^^yup...dont ever use that paper crap...especially the ones they give you. use the stock metal manifold gaskets and just get the damned things welded so we dont have to have these discussions
  17. #17 Re: blow out
    Joliet, IL
    lol i think i will it is also cheaper i just dont feel like ripping it out but oh well....
    00 Silvermist GTP
  18. #18 Re: blow out
    Wichita
    PaceSetters. That's your problem.
  19. #19 Re: blow out
    Jan 1970
    Maquoketa, Iowa
    Nothing wrong with the pacesetters if you put them in right the first time. To weld in the v-band its best if you took the y pipe off and rest of the downpipe so that the flanges can be welded on each. If you take the y-pipe off, you might as well take the crossover off with it and weld that to the y-pipe, so before you take the y-pipe off mark where it is lined up at on the y-pipe. So that way all you have to do is drop the y-pipe through, hook it into the rear header, clamp it and tighten the v-band. Or take the rear header out and weld that also.
  20. #20 Re: blow out
    Wichita
    Quote Originally Posted by FoSHO99 View Post
    I've had the exhaust tack welded to the y-pipe twice now.
  1. supercharger blow off valve?
    By 2story in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 06:24 PM
  2. When will my transmission blow
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2009, 08:31 AM
  3. Whats Wrong Did I Blow It Up ?
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 06:10 PM
  4. blown 2 motors need help before i blow the 3rd
    By talonpower2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 05:23 AM
  5. Honda Blow up-a-thon
    By UR LOSN in forum Off Topic Discussion
    Last Post: 02-24-2008, 10:32 PM
