Thread: acdelco pf52 oil filter
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    I live here. UR LOSN's Avatar
    Rockford, IL
    where does one find this oil system?
    GTP Level Member GTPluv's Avatar
    Enid,Ok
    From Scotty! He don't know much about oil, but hey, he does it anyway.hahaha
    Jk. Scotty's the man!
    Oklahoma
    Quote Originally Posted by GTPluv View Post
    I know where you live woman and Im not directionally challenged either. I just got a Tom Tom and I'll drive to your house house.
    Enid,Ok
    Um.....I moved!
  5. #25 Re: acdelco pf52 oil filter
    Toronto
    The PF52 is the longer filter. PF47 is the shorter 'stock' filter.
    5W30 is thinner than 10W30, but Only at temperatures of 40*F and less.
    At operating temperatures 5W30 and 10W30 are the same
  6. #26 Re: acdelco pf52 oil filter
    May 2008
    staten island,NY
    i wouldnt run the longer filter, it sits too close the the lower control arm, a big enough bump and im sure it will cause damage. i run royal purple, i bought the 5 gallon jug from jegs for $125, cheaper than 50$ for 5 quarts from pep boys
  7. #27 Re: acdelco pf52 oil filter
    Toronto
    My oil filter hangs over the subframe. The control arm can't touch it. Been using the longer filter for over 5 years without a problem.
  8. #28 Re: acdelco pf52 oil filter
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    Quote Originally Posted by QwikGT View Post
    if your oil filter is over your control arm you got waaaaaay bigger problems than whatever a longer filter brings.
    I will say when the crappy AZ motor mounts collapse it can make an oil change a chore.
  9. #29 Re: acdelco pf52 oil filter
    May 2008
    staten island,NY
    i run the stock filter, there was a local guy with the longer filter and the lower control arm smashed it up
  10. #30 Re: acdelco pf52 oil filter
    Aug 2008
    vegas
    to repeat --- if the control arm hit the oil filter there are far larger problems with the car than the longer oil filter.
  11. #31 Re: acdelco pf52 oil filter
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    I have been running the M201 for over five years with no problem whatsoever. Bobistheoilguy.com is a great site for oil information. I have to agree with the synthetic and dyno oil being completely compatible. Go to that site and do some reading if you have questions on any kind of fluid except bodily......
