So I was told the sway bar had a crack in it. They quoted me $363.00 to replace it? Do these normally crack?
Price is very steep. Even at list price the stock sway bar is $180. PN 10284146
A heavy duty stock replacement sway bar from GM is only $80 list. PN 12498643 and should be able to be had for less.
The labor to put a sway bar in should be an hour or less. I can do one in 30 min and I am not a mechanic.
I would suggest buying the heavy duty sway bar and having them install it, or doing the work yourself.
And yes, sway bars are known for cracking all the time on our cars. The heavy duty ones do not seem to crack as much.
They want to put in a Dorman sway bar. I'm told the price is $219.00 I found it online for $120.00.
They actually offered to lower the price to $261.00 since they are in there.. $150.00 for the parts and then labor..
Is Dorman good or should I go with GMPP sway bars?
Should I replace the rear sway bar?
Buy the GMPP yourself and have then install them.
Doorman = OE or less quality
You guys are the best...
part number 12498643
Found the bar at local dealer. $87.00. They will charge me $90.00 to install it..
glad I have you guys... I'm already spending $1800 at the mechanic... its the least he can do..
What are you spending 1800 on?![]()
Auto Parts Direct To You | AutoPartsDirectToYou.com
This place states the stock one is hollow. Is this correct? If so, I'll replace front and rear, regardless if they're cracked or not.
you need to see all my other posts...
complete brake job. new rotors, loaded calipers, new brake line. Brake line ruptured.. about $900.00. They will be painting my calipers black.
trans flush with new filter.
oil change
new window regulator/motor
Power steering fluid change
of course the sway bar..
I'm probably forgetting something...
Then I need the A/C fixed... I really hope its nothing major. A few hundred I could live with.. Another $800.00 to fix AC and it will throw me over the edge..
Holy sh*t.
That sucks, not mechanically inclined at all or have any friends that are?
No not really.. Don't have any friends that are either...
Oh and I forgot to mention the things I will do myself
New speakers, all the way around..
Fix HUD display. I will try to resolder that part..
replace headlights. They are discolored... Can someone point me to a part number? Is this easy to replace?
Plus I need to bring it in to have the seats re-stuffed. Probably another $300-$500..
I should add the car was given to me.. Like I said its a 2000 GP GT with only 45K miles.. The outside is in mint shape.. I hope with all of these repairs the car lasts at least 2-3 years without any major problems..
Not sure on stock replacements but they're typically kinda expensive, most people just jump for projectors because that seems to be one of the gripes of these cars, crappy headlights.
1997-2003 GRAND PRIX PROJECTOR HEADLIGHT 1998 1999 2000 on eBay.ca (item 110455927612 end time 10-Dec-09 00:22:41 EST)
Ebay is the cheapest place to get them.
its two 10 mm bolts then they can easily pop out.
Good luck with that!
ebay headlights are ok if you never use them. once you turn them on at night you will see them shake with every little bump you hit in the road. you, and other cars around you will see them shaking on the road signs. its embarrassing. i know this from experience
heres a little secret on the sway bars, check out Summit Racings website, the GM Performance Parts sway bar is dirt cheap. Couldn't find a OE replacement for under 110 until i checked here, the main store is 30 minutes from me so i'm not sure how steap there shipping is
