Thread: Supercharger fluid change 01 gtp
Results 1 to 17 of 17
  1. #1 Supercharger fluid change 01 gtp
    SE Level Member brownb66's Avatar
    Nov 2009
    Battle Creek
    Hello again all. I successfully just changed out the hub on the driver's side and now it runs real smooth with no vibration. Next step is to change the supercharger fluid. I have not done this before and am hoping to get some advice from some fellow GTP'rs. I know its overdue for some maintenance, so please, if anyone has any relavant information, it would help alot.
    Make/Model - 2001 Pontiac Grand Prix GTP
    Miles - 120k
    I was told it might be best to just take it to a dealer but like everyone else I don't wanna spend an arm and a leg. What type of fluid is best? About how long? Any certain thing I need? Thanks in advance.
  2. #2 Re: Supercharger fluid change 01 gtp
    Donating Users blowfishRus6's Avatar
    g.a.
    its very simple. unscrew the hexhead ??? in the supercharger on the front side and stick a squerter from a windex bottle or something down in the hole and simple squert it out into something. then poor some supercharger oil in it. you can get some from gm, some people just use gear oil. your choise.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: Supercharger fluid change 01 gtp
    PA
    Dealers typically won't change the fluid. Some might.
    I went to Wal-mart, bought a turkey baster for like $1.30 and put a piece of vaccum line on the end of it. I can suck almost all the fluid out at once. Then add the new GM stuff. Quick and very easy.
    2001 GSE
  4. #4 Re: Supercharger fluid change 01 gtp
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Haha my dealership told me they'd do it for $600 since the ONLY way to remove it was taking off the supercharger. I instead just bought 2 pts and did the windex squirter method
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  5. #5 Re: Supercharger fluid change 01 gtp
    Jan 1970
    Maquoketa, Iowa
    Just make sure you get a real good whiff of the oil when you take the plug out.
  6. #6 Re: Supercharger fluid change 01 gtp
    GT Level Member Will5600's Avatar
    subs of chicago
    how many botles of gm super changer oil do u use
  7. #7 Re: Supercharger fluid change 01 gtp
    Charles City, IA
    Fill it up to the bottom of the threads. Normally takes about 2.
    SMGPFC Two Nipple General
  8. #8 Re: Supercharger fluid change 01 gtp
    GT Level Member Joe m's Avatar
    mesa,az
    how much does the oil from gm cost?
  9. #9 Re: Supercharger fluid change 01 gtp
    Nov 2008
    I paid $10 a pint. I've noticed it varies from dealer to dealer though
  10. #10 Re: Supercharger fluid change 01 gtp
    subs of chicago
    can u over fill
  11. #11 Re: Supercharger fluid change 01 gtp
    Charles City, IA
    No it will just run out then.
  12. #12 Re: Supercharger fluid change 01 gtp
    GT Level Member skidoojames151's Avatar
    seattle
    to be exact its 6 ounces...gm makes the bottle 4 oz so u gotta buy 2 and have a little left to top off later..
  13. #13 Re: Supercharger fluid change 01 gtp
    SE Level Member pizzi22's Avatar
    Houghton, Michigan
    Yeah fill it to the bottom of the threads, 2 bottles to cover it, I used the Windex Squirter method as well...Easy job...$600!!..hahaha..did they try to sucker money out of you.
    3.4 ZZP Modular Pulley, K and N FIPK, 180 t-stat, DHP V 1.0 PCM, Autolite 104's, Taylor 8mm Red Wires, SSAC Headers, Dynomax Tips, High-flow mufflers, Drilled and Slated Rotors, 13.5 Jl audio w6's, U.S. Amp MD3D, Lanzar 500x2, Blue Underglow, 3 Optima Red top batteries
  14. #14 Re: Supercharger fluid change 01 gtp
    PA
    Quote Originally Posted by ninnyGTP View Post
    I paid $11 for a 4oz bottle.
    A pint is 16oz and I have never seen a pint bottle sold through the dealer. If you did buy a pint, please post a PN for it.
    2001 GSE
  15. #15 Re: Supercharger fluid change 01 gtp
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    I paid $7.50 each when I bought two (2) 4oz. bottles. I used all 8 oz. when I changed mine out.
    The smell stank up the whole shop - it's horrible.
  16. #16 Re: Supercharger fluid change 01 gtp
    Charles City, IA
    I liked the smell.
  17. #17 Re: Supercharger fluid change 01 gtp
    Apr 2009
    I liked the smell.
    You have issues, bro!
  1. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  2. Fluid
    By BwolfGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2009, 11:11 PM
  3. tranny fluid change ?
    By NEONNIGHT34609 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-19-2008, 09:48 AM
  4. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
  5. How much fluid does the s/c take?
    By brodyman in forum General Tech Discussion
    Last Post: 09-17-2008, 02:15 PM
