Thread: Mods
Results 1 to 12 of 12
  1. #1 Mods
    ohio
    I have 1997 grand prix non supercharged looking for some help with some mods to my car. thank you
  2. #2 Re: Mods
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    i have a 3" fwi system for sale, comes with everything needed 2 install and a new silver filter, no cutting, drilling or removing the headlight and bumper 2 install. i had it customized, its also heat wrapped. theres pics in my albums under my user name if u wanna check it out.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: Mods
    Charles City, IA
    Read the safely modding your 3800 thread. In gen tech section.
    SMGPFC Two Nipple General
  4. #4 Re: Mods
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    Safely modding your 3800 powered car!!
    and read it again incase you missed something.
    then feel free to ask some questions
  5. #5 Re: Mods
    Wausau, WI
    As stated directly above me^^^^^^^^^^^^^^^^^^^^^^^^
  6. #6 Re: Mods
    Donating Users blowfishRus6's Avatar
    g.a.
    top swap it. your not gonna get much power out of it with out boost. well you could always spray it
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: Mods
    Jersey
    Quote Originally Posted by blowfishRus6 View Post
    that weak trans won't like it
    16' wrx sti- stock
  8. #8 Re: Mods
    g.a.
    bio rocked it for a while. gotta be nice to it.
    its slow.
  9. #9 Re: Mods
    the non-hd trans only has different gearing and a weaker differential. if you think that is what makes the transmission strong then youre in for a rude awakening. i would never buy an hd transmission and settle for crappy gearing.
  10. #10 Re: Mods
    You would if you had a turbo.
  11. #11 Re: Mods
  12. #12 Re: Mods
    oh well...what do you know...you never had a fast grand prix and mine never runs...were boned
  1. 3.4 mods
    By N8Dogg98 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-22-2010, 09:34 PM
  2. What mods?
    By CompCam21 in forum General Tech Discussion
    Last Post: 07-07-2009, 11:24 PM
  3. 05 GTP Mods
    By shanester in forum General Tech Discussion
    Last Post: 06-12-2009, 10:25 AM
  4. First Mods, what should they be?
    By SteelCityTA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2009, 04:57 PM
  5. First Mods
    By 1998xGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2008, 01:36 PM
