Thread: help please with serpentine
Results 1 to 12 of 12
  1. #1 help please with serpentine
    Nov 2009
    groton ct
    i need help with routing my serpentine belt.
    is it possible to route it with the ac?
    i have a 1997 PONTIAC GRAND PRIX - V6 3.8L 231ci GAS FI N K, the ac is on the bottom right.
    thank you for any assistance
  2. #2 Re: help please with serpentine
    May 2008
    McHenry IL
    ac is on the bottom closest to the front of the car. OUR CARS do have a belt routing diagram on the core support. unless your is peeled off?
  3. #3 Re: help please with serpentine
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    U half to get a ac bypass pulley that goes inplace of your ac comp.
    The diagram should b on the pass strut tower too
  4. #4 Re: help please with serpentine
    GTX Level Member cerick08GP's Avatar
    This is the only picture I could find for you. It is for an 04, but should work for you. Is this what you wanted?
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: help please with serpentine
    Wausau, WI
    Here is a link to the series II set up:
    http://www.grandprixforums.net/f81/engine-pulley-list-2486.html
  6. #6 Re: help please with serpentine
    Nov 2009
    groton ct
    cerick that is the diagram for the full belt but i am looking for it without the a/c which is on the bottom corner i was told to just put the pulley on without the a/c compressor hooked up for now, not sure if this is right but going to try it, thank you tho
  7. #7 Re: help please with serpentine
    Wausau, WI
    yes, you can't really do it without that pulley. You need a dummy pulley as you stated.
  8. #8 Re: help please with serpentine
    So, I think I’m getting it. You want a belt routing pattern for an A/C delete setup. Well, to be honest I have never heard of a car with a serpentine belt route that could just skip a component and still work properly. I have always heard of people just adding dummy pulleys and maintaining the stock route.
    2008GP
    2002GP||sold
  9. #9 Re: help please with serpentine
    Even if you were to totally negate the A/C as a whole...you physically can't just get a smaller belt...in order for it to wrap tight enough it would hit the water pump...making it fail. Just get the A/C bypass pulley and bracket.
  10. #10 Re: help please with serpentine
    Nov 2009
    groton ct
    thank you all for ur input
  11. #11 Re: help please with serpentine
    Unless your AC compressor is bad...I'd probably mention that there's not enough of a difference to remove it. If you are removing a good compressor, please pm me. I'd be interested in buying and wouldn't need shipping.
  12. #12 Re: help please with serpentine
    Nov 2009
    Jax, FL
    Hey guys! I used the search function and found that it appears the only option I have to bypass the a/c is to get the a/c bypass pulley.
    My girlfriend has a 99 GTP and the a/c clutch is apparently going out, a loud noise coming from that area and Is sounds like the same thing when my a/c clutch was going out on my Camaro. She was told it would be about $900 to fix it because they need to replace the compressor, etc. She's getting a new car In December and giving me the GTP since I totaled my truck and I don't need A/C so I'm just going to do the A/C bypass pulley. It sounds pretty simple to do and cheap also!
    Now that i'll be taking over the GTP, i'll be using this forum a lot. I was on LS1tech when I had my Camaro and found the forums to be very helpful.
  1. Serpentine Belt Size's [*]
    By WasteU in forum How To Write-Ups/Tech Tips
    Last Post: 11-08-2013, 03:31 AM
  2. GXP serpentine tensioner
    By 05 GXP in forum 5.3L V8 (LS4)
    Last Post: 07-23-2009, 11:38 AM
  3. Serpentine Belt Trouble
    By butch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2009, 03:09 PM
  4. serpentine tensioner
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2009, 08:20 PM
  5. serpentine belt
    By keenan00gtp in forum General Tech Discussion
    Last Post: 01-25-2009, 11:43 AM
