Thread: Bad Lifters?
Results 1 to 17 of 17
  1. #1 Bad Lifters?
    Quakertown, PA
    Hello everyone....just found this site and this is my first post.
    I have an '02 GP N/A 3.8L. Just recently, I have been hearing a loud ticking sound from the engine when starting. Plus, it idles very roughly until it's driven about 3-4 miles. After the engine warms up, the ticking noise goes away and the idle smooths out. I am pretty sure it's one or more lifters that are causing the noise. I have watched the 33 min. video mentioned here a couple of times and I think I could probably handle the project of replacing the lifters. One thing that bothers me from the video is the mention of the plastic "elbows" on the alternator bracket. How are they attached? And, how hard are they to put in so they don't leak?
    In the meantime, I have tried putting a quart of Rislone into my oil pan and it seems like it is a little better, but the noise is still there somewhat.
    Am I safe to run the car a while with the noisy lifters? Or, am I creating more damage by doing this?
    Thanks for any advice you all can give.
  2. #2 Re: Bad Lifters?
    Charles City, IA
    Yeah it sounds like a bad lifter or 2. The plastic elbows just get pushed in. Just buy new ones when you do it and you will be fine. I would do the lifters when ever you get a chance.
    SMGPFC Two Nipple General
  3. #3 Re: Bad Lifters?
    Quakertown, PA
    Thanks for the info. Another question I have is that somewhere I read that the bolts that hold the rocker arms get "stretched" when originally installed and that you must buy new bolts to re-install the rocker arms.
    Is this true?
    Thanks again for any help you can give to me on this project.
  4. #4 Re: Bad Lifters?
    Charles City, IA
    yup you need new rocker bolts.
  5. #5 Re: Bad Lifters?
    Apr 2009
    Ohio
    When replacing the lifters, is there a certain way they are put in? Two sides of the lifters are flat.
  6. #6 Re: Bad Lifters?
    Guam
    The coolant elbows are plastic and can easily break just from romoving. Both elbows have ends that are on the belt tensioner, coolant runs from one elbow, thru the tensioner, and then thru the last elbow. The two elbows are most parts stores are literally $4.00 for both. If you remove the tensioner, buy the elbows in case you break them, most likely they will break on you. A very, very, stupid design!
  7. #7 Re: Bad Lifters?
    The lifters do go in a certain way.
    When you hold a lifter you will see the roller edge on one side and the dimpled side with no roller. The Roller side goes down towards the camshaft, hence why they are called Roller Cams. I would get the GM TTY bolts unless you plan doing this again to get high ratio rockers IMO. I got a full set of TTY bolts and Re-Usable Comp Cams bolts if your interested...let me know...send me a message.
    As for lifters...if you can get a deal get some new OEM L36 lifters...if not...get some LS7 Corvette Z06 lifters...a lot quieter IMO.
  8. #8 Re: Bad Lifters?
    Apr 2009
    Ohio
    I knew the roller side went towards the cam. I should have clarified what I meant. My question is does the roller go in paraelle or perpendicular to the cam?
  9. #9 Re: Bad Lifters?
    Feb 2008
    The roller's axis is parallel to the cam's axis.
  10. #10 Re: Bad Lifters?
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    Hey, new to the block and posted a similar question!! Should have read more into it!! First, does anyone have the link to the video mentioned above? I am getting new lifters as well and was debating getting the comp cam's one but mentioned above to get the Corvette LS7 lifters.. I plan to further mod the car and would like to get better stuff while I'm in there fixing issues at hand so any more info or opinions regarding this would be appreciated!! Right now my car has a resonator delete Flowmaster cat back exhaust system and I have a Magnaflow high flow cat and Ubend delete pipe ordered (then this happens). I will start on motor mods once I get it running back right again!!
  11. #11 Re: Bad Lifters?
    SE Level Member pizzi22's Avatar
    Houghton, Michigan
    Where is the ticking coming from, could be many things. Possible exhaust manifold gasket, cracked head, or even lifters. What are you current mods? Once you have the way for the air to get out(exhaust mods), it's time to get it into the engine (air flow in should equal air flow out).
    3.4 ZZP Modular Pulley, K and N FIPK, 180 t-stat, DHP V 1.0 PCM, Autolite 104's, Taylor 8mm Red Wires, SSAC Headers, Dynomax Tips, High-flow mufflers, Drilled and Slated Rotors, 13.5 Jl audio w6's, U.S. Amp MD3D, Lanzar 500x2, Blue Underglow, 3 Optima Red top batteries
  12. #12 Re: Bad Lifters?
    Quakertown, PA
    Someone asked where they could find the video I mentioned in my original post. Here's a link to the video. It's very infomative.
    http://www.cpaclubgp.com/misc/lim-gasket.html
    Just an update to my original post.
    I originally had a very bad lifter noise and my car would run like crap for a couple of minutes until the lifter quieted down. I added a full quart of Rislone to my oil and ran it for about a week. This seemed to quiet the lifter down somewhat but it didn't completely get rid of the problem. After a week, I changed the oil, put in Castrol GTX 10-30 plus one half quart of Lucas oil treatment. Oh, changed the filter to AC/Delco too. This has dramatically reduced the noise now to just a little rattle on startup for a few seconds and then quiet. (well, at least quiet for a 3.8L....LOL !!). I am going to run it for a while to see if the lifter noise comes back. If so, then I guess I am going to have to do the whole lifter changeout.
    Thanks again for your input. I really appreciate it.
  13. #13 Re: Bad Lifters?
    Nov 2009
    Tennessee
    Thanks for the link!!!
    I have heard pros and cons with the Lucas stuff.. Don't get me wrong, Lucas makes some of the best stuff out there but dang that stuff is THICK!!!! I don't see how it can do what it does!!! But Good luck, I think I am off to order lifters for mine..
  14. #14 Re: Bad Lifters?
    Lucas is great. Comp Cams lifters SUCK...and they are loud and clattery...you think a ticking lifter is bad? Try listening to comp ones.
  15. #15 Re: Bad Lifters?
    Nov 2009
    Tennessee
    I haven't ordered any yet!!!!! What should I get?? I'm tearing into it this weekend and am wondering if the parts stores one are ok or should I use something different?
  16. #16 Re: Bad Lifters?
    LS7 Lifters...
    This is where I got mine awhile back...price has gone up a tad but not much.
    GM Replacement LS7 Lifters
  17. #17 Re: Bad Lifters?
    Nov 2009
    Tennessee
    I'm assuming $129.99 for a set, that's cheaper than the Comp Cams lifters!! Now if you don't mind me asking what's the difference? Will I need new pushrods and rocker arms or are these just a direct replacement?? Just wondering why they are better.. I have heard several times from other people that Corvette lifters are better to use but never heard why? I mean if I went to the local parts store they are $10 to $12 a piece so I'd rather go this route, I mean $9 more for better ones over my stock ones.. No brainer.. Thanks!!!
  1. where to get Ls7 lifters???
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2009, 01:05 PM
  2. Lifters
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:46 AM
  3. Morel Lifters for V6!!!
    By UR LOSN in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 04:01 PM
  4. L26 Lifters and Flexplate in L67?
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-17-2008, 12:13 AM
