Ok here is my problem. I received my WBody HID kit from the Branson GPM and I just recently installed them, about 3 months ago, and ever since then I have had problems with them.
Originally when they were first installed, I just used the harness that Wbody provided that connected to the factory plug on the lights then connected to the ballast of the HIDs. Whenever I would turn on the lights, either the left or right HID would not want to come on. I would have to flick the high beams to get the ballasts to start up. This has been a constant problem since I have had them installed.
Just a week ago I got a new wiring harness for the HIDs to run independently from the stock wiring and work solely off the battery for direct power to help correct the problem as many have suggested would fix it. However even after installing the wiring harness the problem still persists. It is not as severe as before the wiring harness was installed but it is still going on. Also I find at times the right side HID flickering from time to time. It is very annoying.
The new setup is as follows. The new wiring harness is connected to the battery, it’s a has a nice big HID relay switch that feeds to lines that go to the power for both ballasts and one plug that plugs into the aftermarket harness that WBody provided. All grounds are good and the lights are working, but not as intended I am sure due to the problem listed above. I am only using one of the aftermarket harness' that WBody provided to plug in from the passanger light assembly into the new HID Wiring Harness that then plugs into the ballast on the right side. The driver side wiring of the HID wiring harness plugs directly into the ballast, no WBody aftermarket wiring harness used on that side of the assembly.
I know Chris, Webracin, had created a little device that was supposed to delay the HIDs from activating, but I never heard anything else about it. I sent him a PM or two on the National Boards back in the days before all the fallout there.
Does anyone have any suggestions on what might be the “fix” to this problem or suggestions to help correct it? Or could it be a problem with the ballasts themselves? The ballasts from WBody are pure chrome looking and do not have any labels at all on them. I could not even determine who the maker would even be of them.
Many thanks for reading all of this.![]()
