Thread: Airbag turns off & on
Results 1 to 4 of 4
  1. #1 Airbag turns off & on
    SE Level Member summersGT's Avatar
    Mississippi
    We own a 2007 GT and the passenger airbag light switches from on to off for no known reason when a passenger is in the seat (I think it may even do this with no passenger). It goes from off to on ranging from every few seconds to every few minutes. I assume this is some kind of sensor or something but haven't been able to find anything about this issue. I expected to find out it was a recall issue, but found nothing. We are really worried about this because my wife carpools and usually has a passenger that may or may not be protected by the airbag in the case of an accident.
    Has anyone had this problem? Can you tell me how to fix this?
  2. #2 Re: Airbag turns off & on
    Wausau, WI
    is this with a small child in the seat or an adult or does this do it when empty for sure. As far as I knew there was a certain weight sensor that was in the seat so that it would auto turn off when no one or a baby in a car seat was strapped in there. I would GUESS that it is a faulty sensor for that seat if it is not acting correctly.
  3. #3 Re: Airbag turns off & on
    Mississippi
    She said it does it even when there is no passenger. Did it with me in the seat last night and I weigh 140.
  4. #4 Re: Airbag turns off & on
    Wausau, WI
    I would say bad seat sensor or relay for it......still guessing though.
  1. srs airbag
    By pacothetaco in forum General Tech Discussion
    Last Post: 08-02-2009, 11:13 PM
  2. airbag/compass
    By Clar2478 in forum General Tech Discussion
    Last Post: 01-13-2009, 01:06 AM
  3. What wire turns on amp?
    By rtb in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 08:13 PM
  4. srs airbag light
    Last Post: 02-03-2008, 07:46 PM
