the latest....
i had a misfire in cylinders in 4 and 5 mostly....thought it was a bad plug....so i switched plugs 3 and 5 to see if the misfire followed nope....switched the wire to cylinder 5 next and still after all this almost all my misfires are cylinder 5...so tomm i will try getting 104's and start the gap at .045 aand increase gap with every plug change to see what i can run....if that doesnt fix it i guess it blue gtp will be the winner with the ICM or coils took a shyt ....thanks for the help guys ill keep you posted...
There you have it...you still need to listen to SHO...you need colder plugs..and a proper gap.
No...it isn't running a 2.6"...in fact it isn't running at all...but this is the setup I am currently building...should be done here soon.
Should have just went turbo.
104's @ .045 are in gonna drive to school ill let you guys know how it ran when i get back
104's at .045 killed all my misfires.....btw mini i will be getting that ported sc housing soon to kill my last 1-2 * of kr! i still have a new issue though its not misfire related so i made a enw post
so would a bar straw be considered an upgrade then? nice sig...
