Thread: Common Problems?
Results 1 to 12 of 12
  1. #1 Common Problems?
    Minneapolis
    To start off, I drive a 2000 Grand Prix SE 3100.
    Yeah, yeah. Its "slow" compared to the rest of you. Whatever.
    Its just my daily driver.
    I was just wondering if anyone could tell me common problems with these pontiacs. Its got 142k (low compared to most near me!). I used to drive a 95 Ford Mustang GT with a 5.0. Now THAT was power.
    Anyways. I lost my mustang this spring due to a drunk driver, and switched to a pontiac. It ran great for 10k miles (all put on within 3 months, so I'm VERY pleased that it ran withoutproblems. Loved the mustang, but sports cars are flakes). Now its starting to act up. It runs fantastic still, but I've noticed a noise coming from a belt and a mechanic told me its something to do with keeping the engine cool/a belt is starting to rub & metal is rubbing metal? I don't know. I wasn't really listening.
    The point of all this is that its starting to have little problems here and there, and I've heard that once Grand Prixs get one problem they go downhill fast. Is this true? What are common problems for this age/mileage/engine type? Should I just sell it off before it goes bad, or is it worth fixing?
    Thanks for any answers!
  2. #2 Re: Common Problems?
    SE Level Member reveregtp's Avatar
    Nov 2008
    Revere, MA
    hmm any problem left alone too long can lead to further damage. from my years of driving gp's i find that if you fix one problem as soon as you recognize it you'll be fine... my daily driver doesnt give me any headache at all, and ive had it 35k now. i JUST did spark plugs and wires on it the other day and i just keep up on checking the fluids. The cars can be tanks if maintained properly
  3. #3 Re: Common Problems?
    Minneapolis
    Alright thanks.
    Does any one know of common Grand Prix problems?
    I've heard issues withhead gaskets?
  4. #4 Re: Common Problems?
    Wausau, WI
    LIM gaskets, MAF sensors, Crank Sensor, coolant elbows....but this doesnt mean it will be on your car. It all depends on how well it was taken care of before you bought it. Many of these go to 200k or more, but some have problems at 50k. It depends on maintenance, driving style, and many more details. I think almost any car that is 10 yrs old with over 100k could possibly have several issues go within a short period of time, then again it could go 200k with no issues. you can never pinpoint a specific age or mileage on any vehicle.
  5. #5 Re: Common Problems?
    The 3100 is known for head gasket issues...I'd say if you are ever seeing a small increase in engine temps and low coolant...I'd get them changed
  6. #6 Re: Common Problems?
    Wausau, WI
    on the 3100 yes head gaskets and the LIM gasket.
  7. #7 Re: Common Problems?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    i bought my 01 GT in november of 08. i havent even been paying on it for a year, and heres a list of things ive had to replace on it
    ABS wiring harness
    Upper Intake plenum
    rear main seal plate gasket
    both CV shafts
    both front bearings
    new shocks/struts ALL the way around
    new brakes all the way around
    belt tensioner
    power window motor/regulator
    control arm bushing
    and right now its making a sound that i think is a bad ball joint
    those are just some of things that i can think of off the top of my head right now. also, none of those were repalced cuz i "wanted" it done, everyone of those repairs needed to be done. ive put more money worth of repairs in this car then what the car loan is for, and im not even 25% into the loan. personally, ill never be buying one of these piles again
    edit: i wanted to add, just to let everyone know, dont buy a car based on a CARFAX report or anything like that. my car has a 100% perfect CARFAX history report. needless to say, it was nowhere near perfect
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #8 Re: Common Problems?
    Wausau, WI
    [QUOTE=Jakegday;244765]i bought my 01 GT in november of 08. i havent even been paying on it for a year, and heres a list of things ive had to replace on it
    ABS wiring harness
    Upper Intake plenum
    both CV shafts
    both front bearings
    belt tensioner
    control arm bushing
  9. #9 Re: Common Problems?
    Nov 2008
    Fremont Nebraska
    what?
  10. #10 Re: Common Problems?
    Wausau, WI
    I dont know what happened there. It did not look like that when I posted it....?
    I was saying how you should have looked your car over better before you bought it as I find it hard to believe all of that stuff failed after you bought it. If you didnt know what to look for you should have taken it to someone to look it over with you before you bought it. The guy who owned it before you obviously did not take care of it at all or perform any maintenance on it. I understand a couple of things you could have overlooked but all of that? Plus carfax is onely useful for when people get in reported accidents or have a change in the status of their title from original form. Kind of like dealerships too.....they can only see the info of work done from other GM dealerships. Unless someone takes the car to GM to have the work and maintenance done on it for everything big or small, you will never know the true history of a vehicle.
  11. #11 Re: Common Problems?
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by Liquifire View Post
    lol, now what would make you think that? i bought it from a used car lot that i bought my last car from. my last car was pretty much problem free the 4 years i owned it, and ive also heard good things about the place throughout the years. But yes, as you said, i will NEVER buy a used car again without having my shop look at it. not after this
  12. #12 Re: Common Problems?
    Wausau, WI
    it sucks because they are not going to tell you if there are things wrong most of the time, and they arent going to just replace a bunch of stuff even if they do find it because there goes their profit. Unfortunately they probably didnt look it over that closely either. It is too bad, you can only trust yourself or an independant if you want it done thoroughly or correctly.
  1. Common Acronyms
    By TyroElite in forum General Tech Discussion
    Last Post: 11-07-2019, 07:51 PM
  2. Common Oil Leaks?
    By Angleiron in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2009, 08:09 PM
  3. Is this common?
    By boomboom in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2009, 02:05 PM
  4. Common Grand Prix problems?
    By TronCarter in forum General Tech Discussion
    Last Post: 03-04-2009, 04:38 PM
  5. Common Accronyms
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 11:31 PM
