Thread: Turn signal switch... bad?
Results 1 to 2 of 2
  1. #1 Turn signal switch... bad?
    Iowa
    As can be expected on a 21 year old car w/250,000 miles, things will go wrong. One of these things is the turn signals. On my '88 coupe, the turn signal lever is the same one that does the high beam/low beam and cruise control. After getting this car, I have realized that you have to pull the lever toward you (like you were going to flash the high beams) in order to get the turn signals to work. The trick is pulling the lever back far enough, but not all the way back (blinding the on-coming person). Is there some way to fix this without spending a lot of money or time doing it? As of right now, I haven't mastered it well enough, so the high beams keep coming on when I make a turn, LOL. Please help me!
    1988 Grand Prix coupe (base): Custom two-tone paint - blue/gray - recently quit at 249,092 miles!
    1999 Ford Explorer - daily driver, stock..... for now!
  2. #2 Re: Turn signal switch... bad?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    i would just replace the switch itself. try 2 find 1 at a junk yard. i think i read a forum not 2 long ago with some1 that had the same problem and his started smoking, so u dont want something to short circuit.
  1. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  2. Turn Signal Module
    By Clar2478 in forum General Tech Discussion
    Last Post: 05-09-2010, 04:02 PM
  3. Turn signal switch... bad?
    By 1988 Grand Prix in forum General Tech Discussion
    Last Post: 09-23-2009, 08:20 PM
  4. turn signal switch
    By vailskier3 in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 08:10 PM
  5. wiper/turn signal switch
    By GOINDEF in forum General Tech Discussion
    Last Post: 05-13-2008, 07:52 PM
