Thread: 04 GTP Service ABS/ TRaction control
Results 1 to 4 of 4
  1. #1 04 GTP Service ABS/ TRaction control
    SE Level Member busagtp's Avatar
    chicago
    I have an 04 GTP and i keep getting a message that i need to service my ABS and that my traction control and stability is turned off. I didn't do anything to the car but jack it up trying to fix what i thought was a starter problem is it possible that i could of clipped a wire or messed it up when lowering the car? All input greatly appreciated.
  2. #2 Re: 04 GTP Service ABS/ TRaction control
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    absolutely. an abs sensor wire to be exact. those 2 problems happening at the same time often suggest a bad wheel bearing/abs sensor, or a faulty connection between the sensor and computer
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  3. #3 Re: 04 GTP Service ABS/ TRaction control
    Charles City, IA
    Take you car to a shop and have them scan the abs codes.
    SMGPFC Two Nipple General
  4. #4 Re: 04 GTP Service ABS/ TRaction control
    chicago
    thx fellas
  1. traction control problem
    By Martin 04 in forum General Tech Discussion
    Last Post: 07-02-2014, 11:12 AM
  2. Traction Control
    By tynev7 in forum General Tech Discussion
    Last Post: 08-18-2009, 10:55 PM
  3. reduce engine power / service traction system
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 06:56 PM
  4. ABS/Traction control
    By holsports in forum General Tech Discussion
    Last Post: 03-22-2009, 11:32 AM
  5. Adding traction control
    By FuglyGTP in forum General Tech Discussion
    Last Post: 03-05-2009, 09:25 PM
