Thread: What wears to cause the classic rear camber issue?
Results 1 to 4 of 4
  1. #1 What wears to cause the classic rear camber issue?
    Feb 2009
    NE
    We have 2 GP's and both have the "old VW" look from the rear with negative camber issues. Can anyone explain what wears or changes to cause this? (I know how to fix it with camber bolts or slotting)
  2. #2 Re: What wears to cause the classic rear camber issue?
    Jul 2010
    Huntington WV.
    If you know how to fix it, please do tell. I have tons of negative camber and two wore out tires to prove it. Going for new tires this weekend and I dont want to wear them out quickly.
  3. #3 Re: What wears to cause the classic rear camber issue?
    your springs are getting saggy and old, thus lowering the rear end, thus creating more negative camber. better springs take car of this 100%. same with a good pair of struts.
  4. #4 Re: What wears to cause the classic rear camber issue?
    Feb 2009
    NE
    take the strut bolts out and die grind the strut mount hole slots so as to allow the hub to tilt as needed. It is what I have done. Saved a few tires by now I assume.
  1. Classic Hilarious
    By Mad Monkey in forum Off Topic Discussion
    Last Post: 08-24-2009, 08:09 PM
  2. GTP rear issue..
    By DezGTP in forum Introductions/Noob Questions
    Last Post: 07-07-2009, 03:46 PM
  3. Camber
    By SlowM90 in forum Tires & Wheels
    Last Post: 05-14-2009, 06:01 PM
  4. so you like a Classic?
    By offroadfury6 in forum Off Topic Discussion
    Last Post: 10-02-2008, 08:19 PM
  5. classic episode
    Last Post: 09-15-2008, 01:07 AM
