Thread: too much oil, bad?
Results 1 to 8 of 8
  1. #1 too much oil, bad?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    i just typed out over 2 paragraphs explaining my story only to realize i could do this much faster.
    short and simple, is a half inch over the max line on the dipstick bad? should i get back under there and let a little out??
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: too much oil, bad?
    it probably wont hurt anything in a realistic sense, but you could be safe and empty a little out. its up to you.
  3. #3 Re: too much oil, bad?
    SE Level Member crashman's Avatar
    Perry Hall, Maryland
    Well..............what happens is that the crankshaft whips the oil up into a froth, and puts a lot of air into it. That air in the oil doesn't lube very well. I really wouldn't worry about it to much unless your goina be spinning some high RPMs
    "Time is a great teacher, but unfortunately it kills all its pupils."
    RIP 2000 GTP
  4. #4 Re: too much oil, bad?
    Nov 2008
    Fremont Nebraska
    well within the next 3000 miles, i may hit 5800rpm a time or 2. ill just drain it
  5. #5 Re: too much oil, bad?
    Or...you could get a crank scraper...those things are proven to help...but only on little 4 bangers
  6. #6 Re: too much oil, bad?
    Barksdale AFB, LA
    It's also bad for the main seals when the oil is over filled.
    2009 Subaru Impreza WRX STI
  7. #7 Re: too much oil, bad?
    GT Level Member sasquatch094's Avatar
    cleveland
    just loosen the screw on the oil pan for a couple seconds.. itll take a min of your time and could possibly save some money
  8. #8 Re: too much oil, bad?
    May 2008
    McHenry IL
    yank the plug out for a second and put it back in so what if you get a little oily it wipes off ha
bad, oil
