i just typed out over 2 paragraphs explaining my story only to realize i could do this much faster.
short and simple, is a half inch over the max line on the dipstick bad? should i get back under there and let a little out??
Well..............what happens is that the crankshaft whips the oil up into a froth, and puts a lot of air into it. That air in the oil doesn't lube very well. I really wouldn't worry about it to much unless your goina be spinning some high RPMs
Or...you could get a crank scraper...those things are proven to help...but only on little 4 bangers
It's also bad for the main seals when the oil is over filled.
yank the plug out for a second and put it back in so what if you get a little oily it wipes off ha
