Thread: Hi I have $1000 to spend and want to mod up.
Results 1 to 20 of 32
  1. #1 Hi I have $1000 to spend and want to mod up.
    Weymouth, MA
    Could you guys help me out as I said I have 1000 to spend and want my car to run around 14.0-14.5 in the 1/4 mile is this possible with this amount? If so what mods would you reccomend
  2. #2 Re: Hi I have $1000 to spend and want to mod up.
    Wausau, WI
    if you are willing to do the work yourself, it should be very easily done.........please read all about the steps you will need to take in the "safely modding your 3800" thread in the general tech section.............to sum it up you will need cold air intake or fenderwall intake, either headers/downpipe or plog/downpipe, colder plugs, 3.4 pulley set up and most importantly a tune...........definitely read that thread though.......lots of stuff you should know.
  3. #3 Re: Hi I have $1000 to spend and want to mod up.
    Weymouth, MA
    Quote Originally Posted by Liquifire View Post
    Hey would a tuned pcm help? Also I can do the simple things, but the harder thing I will have to pay to get done
  4. #4 Re: Hi I have $1000 to spend and want to mod up.
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Quote Originally Posted by Enjoijoe View Post
    Changing tables or variables in the pcm is necessary, or at least recommended anytime you do anything to a modern motor. I believe that what LF was referring to as a "tune". You can just send someone your specs, modifications and they will reprogram the module for you, and you can buy/borrow/steal a scanner/programmer and do it yourself. Nice learning curve on that one though. :-p
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  5. #5 Re: Hi I have $1000 to spend and want to mod up.
    well, i might as well ask the easy questions first. do you have a supercharged car?
  6. #6 Re: Hi I have $1000 to spend and want to mod up.
    Wausau, WI
    Assuming you have an 01 GTP.... Yes, I had mentioned for you to get a tune(tuned pcm) and this is the most important part of all. If there is someone in your area to give you a custom tune, this is the best way. Otherwise you can get a tune by mail order too.........All of the parts that I had previously mentioned are not too difficult mechanically to install and there are instructions on here about all of them or you can ask questions if needed. I would leave the tuning of the PCM to a professional if you dont have any experience. So, do you have any more questions yet?
  7. #7 Re: Hi I have $1000 to spend and want to mod up.
    Wausau, WI
    if you found a good tuner it is possible to get close to your goals just by modifying the pcm.....but you will definitely be able to get there safely if you put all of the correct supporting mods on in the correct order. If you just slap a pulley on with no mods and try to tune it you will probably wreck your motor........fwiw.
  8. #8 Re: Hi I have $1000 to spend and want to mod up.
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    lol great question, that would be AWESOME if i could get my GT into the 14 second range for $1000
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  9. #9 Re: Hi I have $1000 to spend and want to mod up.
    CT
    If you can do the work yourself I'd say a set of pacesetter headers, rockers, 3.4" pulley and tune. Could probably get some of the stuff cheaper on here used and have money for other mods.
  10. #10 Re: Hi I have $1000 to spend and want to mod up.
    Weymouth, MA
    yes sir
  11. #11 Re: Hi I have $1000 to spend and want to mod up.
    do the usual 3.4 setup. that will extinguish your $1000.
    - PLOG
    - 3" downpipe
    - intake
    - 180* thermostat
    - autolite 104s
    - 3.4 supercharger pulley
    - and a tune to tie it all together.
  12. #12 Re: Hi I have $1000 to spend and want to mod up.
    Weymouth, MA
    - PLOG
    - 3" downpipe
    - intake
    - 180* thermostat
    - autolite 104s
    Thanks for help that sounds good I can't wait to start. Also would an intense pcm be a good tune
  13. #13 Re: Hi I have $1000 to spend and want to mod up.
    canada
    it would be fine. also there is a zzp pcm and Will Overkill can do it.
    Will has a section in this forum
    and zzperformance.com
    Good luck
    1998 GTP 2Door
  14. #14 Re: Hi I have $1000 to spend and want to mod up.
    ZZP tunes suck. dont go with them. theyve blown up many cars.
  15. #15 Re: Hi I have $1000 to spend and want to mod up.
    Wausau, WI
    no one should recommend a zzp tune unless they own zzp and get some money out of it...I would go with the DHP from 3800 personally........
  16. #16 Re: Hi I have $1000 to spend and want to mod up.
    Wausau, WI
    Please read this thread..........a recent purchase of a tuned pcm from intense...http://www.grandprixforums.net/f18/n...elp-18899.html
  17. #17 Re: Hi I have $1000 to spend and want to mod up.
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    buy my plog and my 3"d/p...or send me the $1000.
  18. #18 Re: Hi I have $1000 to spend and want to mod up.
    Weymouth, MA
    - PLOG
    - 3" downpipe
    - intake
    - 180* thermostat
    - autolite 104s
    hey with that setup what do you think i would run in the 1/4mile
  19. #19 Re: Hi I have $1000 to spend and want to mod up.
    high 13s if you know how to drive your car being realistic. there are people out there that will swear up and down that a 3.4 setup will do mid 13s, which i dont believe in the least.
  20. #20 Re: Hi I have $1000 to spend and want to mod up.
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Well I have a basic 3.4 setup on my gtp(mods listed below)and on a kinda hot 90* day in kansas city I ran a 14.1 after figurin out where she likes to be launched. Took me like 7 tries before I got it right. I think with a colder day, I could pull off a high 13. Or at least I'd like to
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  1. $750 to spend what are the must do mods??
    By Enjoijoe in forum General Tech Discussion
    Last Post: 06-23-2009, 01:36 AM
  2. I've got $800 to spend on my GP GT...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 04:04 PM
  3. Not how I wanted to spend my Sunday
    By jester in forum The Rant Forum
    Last Post: 02-09-2008, 06:37 PM
