Thread: ZZP Front Strut Bar Install
Results 1 to 6 of 6
  1. #1 ZZP Front Strut Bar Install
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    OK I have this strut bar from ZZP:
    ZZ Performance
    The strut bar is about a half inch to short. I can't drill a new hole because there isn't enough width on the brackets to do that. Does anyone have any tips? Thanks.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  2. #2 Re: ZZP Front Strut Bar Install
    That sucks...I'd send it back and make them put new brackets on it.
    ZZP FTL yet again.
  3. #3 Re: ZZP Front Strut Bar Install
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Are you doing this when the front end in the air? That can make a small difference.
    Could also be an 04+ vs 97-03 issue.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: ZZP Front Strut Bar Install
    SE Level Member 07CrimsonGT's Avatar
    Apr 2009
    Oxford, Ohio
    +1 on the fitmment issue. Give them a call, and see whether or not it is compatible with your 04. Having an 07 myself, I have noted that there seems to be a whole lot more after market stuff for the 97-03 cars.
    Don
  5. #5 Re: ZZP Front Strut Bar Install
    Feb 2008
    South Bend, IN
    I called them up and asked them before I ordered it if it would fit my '04 and they said yes. Theres a guy who wrote a review on it in the review/comment section under the product who said he put it on his '05. I tried jacking up one side of the car to see if that would make a different, it didn't.
    I don't understand why they don't say what freaking car it fits on their product description. After my 8 month old crack plog and now this, I'm done with ZZP.
  6. #6 Re: ZZP Front Strut Bar Install
    not a fitment issue. lift the front of the car up in the air. i have the same bar, its tight, but it fits. you can always use a little hammer persuasion.
    i recommend this bar over any of the others because it uses all three strut bolts.
  1. Front Sway Bar Install Issue
    By rileystanek in forum Brakes/Suspension/Chassis
    Last Post: 07-12-2009, 11:12 PM
  2. How to install new front speakers on a 97 Pontiac Grand Prix?
    By GothTP in forum Audio, Security & Visual Electronics
    Last Post: 07-01-2009, 07:59 AM
  3. Front Strut Mount from Advance Auto Parts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 04-02-2009, 11:53 AM
  4. 98 NAPA Front Strut Tower Mount
    By Lion29GTP in forum Brakes/Suspension/Chassis
    Last Post: 03-10-2009, 02:10 AM
  5. How do I install front license plate on 2006 Gran Prix
    By DMC-12 in forum Off Topic Discussion
    Last Post: 02-16-2008, 11:43 PM
