Thread: caliper bracket
Results 1 to 4 of 4
  1. #1 caliper bracket
    Donating Users
    Plainfield, IL
    are all the caliper brackets off 04+ impala's a 12 inch bracket ? looking to do a 12 inch upgrade on my fronts and need to know if these brackets will all be 12 inchs if off this year car, it will bolt right in right?
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: caliper bracket
    Donating Users mystic231's Avatar
    Michigan
    You're looking for GM Part No. 18029829. It should bolt right in.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  3. #3 Re: caliper bracket
    Banned - Busted For Scamming
    Feb 2009
    Yes, they are to answer your questions. The only thing you need is the caliper bracket and rotors. Everything else is the same.
  4. #4 Re: caliper bracket
    thats what i have, the 12" calipers. they work and work great. i like how they are a stock setup. im glad i went with this setup over f-bodies. it was also mega cheap (~$60 total)
  1. N * Bracket
    By Makdaddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2009, 09:13 PM
  2. caliper bracket
    By gotboost3 in forum Brakes/Suspension/Chassis
    Last Post: 02-11-2009, 08:44 PM
