Thread: Car maintenance
Results 1 to 15 of 15
  1. #1 Car maintenance
    Alabama
    I just bought a 99 GT, and it's right at 100k miles. It needs new spark plugs, is there anything else I should change out?
  2. #2 Re: Car maintenance
    GTP Level Member SuperSport's Avatar
    Michigan
    Plugs, Wires, Trans Fluid (drop pan and replace), air filter, add a cabin filter from a Regal, Oil, serpentine belt.
    Thats what I did when I got my GT, and it had 112k.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  3. #3 Re: Car maintenance
    Alabama
    Thanks, but where do I install the cabin filter?
  4. #4 Re: Car maintenance
    Wausau, WI
    Quote Originally Posted by ReaperRob View Post
    It goes under the passenger side wiper cowl. This will have to be removed. If you do this, make sure that you have the piece that did not come stock in these that diverts water away from the cabin intake motor area.....if you dont know what this is just look at the No more water in the floorboard take 2 thread in the how to section. this will also have pics of the area, how to take the cowl off, and where the cabin air filter should be. It also has the gm part number for the water diversion plastic piece(it is literally three or four dollars) this may save your heater/AC blower motor as well.........
  5. #5 Re: Car maintenance
    Wausau, WI
    http://www.grandprixforums.net/f73/w...-fix-6961.html
    here is the link in the how to section..........
  6. #6 Re: Car maintenance
    GT Level Member sasquatch094's Avatar
    cleveland
    why would you add a cabin air filter? jw
  7. #7 Re: Car maintenance
    Michigan
    I dont want to be breating in this.
  8. #8 Re: Car maintenance
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    Im saying this in the best way possible. where the hell is that or do you add it?
    silver 2003 Grand Prix GT List is on it's way to be updated
  9. #9 Re: Car maintenance
    Quote Originally Posted by kjohnson View Post
    its on the passenger side underneath the cowl where the windshield wipers sit. A LOT of cars do not even have a filter. i put one in my GT when i bought it.
    at 100k miles i would debate looking into a new timing chain and tensioner.
  10. #10 Re: Car maintenance
    Nov 2008
    what are the chances of my 03 even having one? and is the stealer ship the only place you can get that piece of plastic that fixes the water in the floor boards? i figure if im that far into it I might as well do some good.
  11. #11 Re: Car maintenance
    i just took mine off and used some caulk underneath it and sealed everything up. the chances are slim that you have one in your car already if you know one has never been changed or put in.
  12. #12 Re: Car maintenance
    Nov 2008
    how much is the filter u think and does it actually make a difference
  13. #13 Re: Car maintenance
    $10? it makes a difference if you have allergies, dunno.
  14. #14 Re: Car maintenance
    Nov 2008
    think it would help by keeping my dash from getting so dusty. that really pisses me off
  15. #15 Re: Car maintenance
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    Probably not. My dash still gets dusty but with the cabin filter after only a couple months I see a bunch of leaves and dust that otherwise would've been through the blower. Most cars these days have one, no reason not to spend the few bucks.
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  1. What happens when you dont keep up with maintenance?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 03-03-2009, 06:32 PM
  2. Low maintenance mods.
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-13-2008, 04:15 PM
  3. Genral maintenance on my 98 GTP?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 04:56 PM
  4. Leather seat cleaning/maintenance
    By Quicksilver_GP in forum General Tech Discussion
    Last Post: 04-25-2008, 09:04 AM
  5. Dodge Dakota Maintenance
    By TyroElite in forum Off Topic Discussion
    Last Post: 01-28-2008, 09:29 AM
