Thread: ongoing Issue with Ignition Main 1
Results 1 to 7 of 7
  1. #1 ongoing Issue with Ignition Main 1
    Aug 2008
    Ohio
    I am having ongoing issues with Ignition Main fuse (40amp) blowing. It has blown twice in the past month. My mechanic has tested out all the wires fed by this fuse and they all test out fine. Anyone experience similar problems?
    BTW, this car was partially submerged a few months back and I have replaced BCM and shifter linkage in center console along with other seemingly unrelated items. Help....
  2. #2 Re: ongoing Issue with Ignition Main 1
    Houston, TX for now
    Sounds like it grounding out somewhere. If it doesn't pop as soon as you put it in then it isn't a constant ground and a meter won't be much help. My ad vice is check around the the linkage and console for any wires that might be pinched. Me guess is a pinched wired that every nowandthen gets enough pressure applied to it to ground out.
    Or the ingnition is on it's way out. Good luck
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  3. #3 Re: ongoing Issue with Ignition Main 1
    Aug 2008
    Ohio
    will check that, thx
  4. #4 Re: ongoing Issue with Ignition Main 1
    Aug 2008
    Ohio
    far from an expert, but doesn't it need to be on the hot side if the fuse is blowing? I've been through about 7 40a fuses in the past week! Car goes into an electronics shop in the a.m.
  5. #5 Re: ongoing Issue with Ignition Main 1
    Charles City, IA
    If you have a short to ground the current will skip the load (resistance) and go right to the ground. That cause the amperage in the circuit to ski rocket. I=v/r ie... if you have 12 volts with .5 ohms resistance= 24amps=blown fuse=mad person= drinking= dui = jail time+loss of license=no need to drive car= plenty of time to fix the problem
    SMGPFC Two Nipple General
  6. #6 Re: ongoing Issue with Ignition Main 1
    Aug 2008
    Ohio
    Shop found a short in wire leading to ignition. $125 and a dozen blown 40a fuses later it should be fixed!
  7. #7 Re: ongoing Issue with Ignition Main 1
    Charles City, IA
    Glad to see its fixed.
  1. Main engine bearing failure
    By 03grandprixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2011, 08:50 PM
  2. I can't take my key out of the ignition!
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-06-2010, 11:10 AM
  3. 3800 SII main cap removal
    By turbocharged406sbc in forum General Tech Discussion
    Last Post: 01-03-2009, 04:27 AM
  4. Main reason for Amp to cut Out
    By jacobmh27 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2008, 09:57 AM
  5. Need More Help, Ignition
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-28-2008, 12:17 AM
