couple days ago on a real cold day my parking brake came on when i accelerated.......it doesnt stay on but it will come on if i hit the gas heavy and it stays on for a couple mins after that.......... has this happened to nebody else ???
Im going to move this over to the Tech Lounge area which is where we try to deal with electrical issues.
No sweat dude, it happens.
is it the park brake light, or is it just the brake light? Is the fluid full?
if it's the parking brake light try and set the parking brake, and release it... and after you release it, pull up on the pedal a bit. coud just be the switch... but yeah, if it's not the parking brake light, check the fluid level
its the emergency brake .... i put it down and released it cause i got all scared at first lol i thought i drove all the way to work with it on but then i realized it just came on so thats when i tried puttin it down and releasing it but it didnt work........ ill check the fluid idk if that is it tho ,but i will let u know
Be sure to report back as well. Helps everyone here that may run into the same thing.
pull the wire off the switch and see if it goes out
the one at the parking brake, if it stays on the problem is somewhere else, if it goes out it's the switch or pedal
