Thread: Starting issue
Results 1 to 8 of 8
  1. #1 Starting issue
    Apr 2009
    Michigan
    I sure hope I can get some help with this issue. I have a 2004 grand prix with about 86000 miles on it. I recently made several trips to Texas from Michigan and back with it and ran flawlessly. I did maintain the car VERY well before each trip, and after each trip. After my last trip is when this came into play. Everytime I start the car after it has been driven a bit that day, it'll stall right after it starts and will continue until I put my foot on the gas and even then it will try and stall. I have noticed that if I don't keep the defroster on so the fan runs it will heat all the way up to right before the red over heat marks as well. It does have a new thermostat, air filter, regular oil changes, new gas tank, the tank filler hose and evap system. Im at a loss, it won't give me a dummy light so im clueless. Any advice or pointers where to check would be VERY appreciated.
  2. #2 Re: Starting issue
    SE Level Member keeno's Avatar
    ontario
    Good luck my friend. I dumped mine when it started to do that. Never did find the fix. I can only guess that the extended run time caused the plastic manifold to lose its seal and create a lean start requiring you to push the throttle to start. I litterally had the exact same problem. The lean condition also creates more than normal engine temperatures. I traded mine for a GXP with the V8. No more problem
  3. #3 Re: Starting issue
    Apr 2009
    Michigan
    damn.....
  4. #4 Re: Starting issue
    ontario
    i will check with some of my old friends at GM and see if there is a quick fix for ya
  5. #5 Re: Starting issue
    Wausau, WI
    Did this do it with the old thermostat? Was the coolant bled properly so that there are no air bubbles in it, is the new thermostat acting properly? I doubt this is it, but I would check it..........
  6. #6 Re: Starting issue
    Apr 2009
    Michigan
    yea it did this with the old one as well, and yes the system has been bleed correctly. I would appreciate it keeno!
  7. #7 Re: Starting issue
    Apr 2009
    Michigan
    well I know its been awhile, but I recently did a tune-up on the car and starts fine ever since. Very glad about that. Just figured I would let the community know in case another pops up!
  8. #8 Re: Starting issue
    Wausau, WI
    Quote Originally Posted by MuTaLiZeD View Post
    odd that this is what would fix it, but i am glad that it was that simple....
  1. Intermittent Starting Stalling Issue
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-04-2009, 07:20 AM
  2. starting car trouble
    By rochaedkj in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-17-2009, 01:12 AM
  3. Starting Issues
    By BigBird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-20-2009, 12:22 PM
  4. 04 gt starting problems
    By borst24 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-27-2008, 10:10 PM
