Thread: NGK spark plugs for stock
Results 1 to 20 of 25
  1. #1 NGK spark plugs for stock
    Wausau, WI
    Just a question.......Does NGK make a spark plug equivalent to our stock ones that is the same heat? Does anyone know the number for them? Thanks
  2. #2 Re: NGK spark plugs for stock
    No but if you plan on modding you might as well drop plug heat ranges now and get some Autolite 605's. They are as close to stock as your going to get minus buying AC Delco's.
  3. #3 Re: NGK spark plugs for stock
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by Liquifire View Post
    Actually, yes they do. The TR55 (copper), TR55GP (platinum), and TR55IX (iridium) are all in the same heat range as the stock plugs.
    But yes - I would run a 1 step colder plug at a minimum - even on a stock GTP.
    Edit: And, little brother - the Autolite 606's are the direct stock replacements.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  4. #4 Re: NGK spark plugs for stock
    I thought that the TR55's were still one step colder. At least that is what all the other sites say...IIRC...
  5. #5 Re: NGK spark plugs for stock
    I could be wrong...but I'm not. NGK is weird on this one - the TR6 is actually their one-step colder plug...where the heat range on the stock plug is actually....6. So it would make sense - and follow the same convention as most of the other manufactures to have the TR5xxxx be the one step, TR4xxx be the 2 step, etc etc etc.
    -Swash
  6. #6 Re: NGK spark plugs for stock
    Where's that damned "blah blah blah" smiley LOL
  7. #7 Re: NGK spark plugs for stock
    I dunno...but I found this one while I was looking for it...
    -Swash
  8. #8 Re: NGK spark plugs for stock
    Wausau, WI
    OK...so TR55's are stock........Tr6's are one step colder? and the TR4's are two steps colder? That labeling system makes no sense.........but if you are right........great. Thanks.......
  9. #9 Re: NGK spark plugs for stock
    Honestly...I say get Autolite 605's. I DO KNOW that they are 1 step colder than stock and help you get rid of KR a little bit more...just a thought since they are basically thre same price
  10. #10 Re: NGK spark plugs for stock
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    what about autolite 104s that everyone seems to like? how much colder are they?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  11. #11 Re: NGK spark plugs for stock
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    NGK TR55 are actual about 1/2 step colder.
    I run the TR55IX iridium plugs and couldn't be happier. DON'T go with NGK TR6 plugs because they run to cold 1.5x colder and your mpg will drop for being stock. I've used both plugs and went back to TR55IX with my current mods.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  12. #12 Re: NGK spark plugs for stock
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by JJ91284 View Post
    2001 Buick Regal LS - Almost Stock
  13. #13 Re: NGK spark plugs for stock
    Quote Originally Posted by Jakegday View Post
    They are one full step...I went through them in the safely modding your 3800 thread...and then the TR6's are inbetween them and the autolite 103's...which are for people with crazy setups...
  14. #14 Re: NGK spark plugs for stock
    Wausau, WI
    what is the difference between iridium and platinum as far as what is the application difference? When is it more beneficial to switch from platinum to iridium? Thanks
  15. #15 Re: NGK spark plugs for stock
    Schaumburg, IL
    Facts
    Good Platinum are rated at approx 100k miles (I wouldn't run them this long)
    Iridiums rated at approx 60k (I wouldn't run them this long, they have extended life versions which are suppose to be on par with platinum)
    Iridiums 6 times harder and 8 times stronger
    Platinums not to be use with Nitrous
    Iridium has 1200F higher melting point than platinum
    I personally change the plugs at half the recommended mileage, usually because thats when I check my belts and swap them out along with fuel filter, and fluids.
  16. #16 Re: NGK spark plugs for stock
    Technically - yes, but NGK always has shown them to be the direct heat range replacement for the L67/L36. X2 on the TR6 - my MPG noticeably dropped when I ran them, too. I don't have any experiences with platinum plugs - I tend to stay away from them.
    -Swash
  17. #17 Re: NGK spark plugs for stock
    Wausau, WI
    I hate to revive this thread, but personally I have been running the copper 104's and they worked great with me. My friend just bought this car from me and he doesnt want to bother with copper plugs. Which iridium plug is the same heat range as the AL104's? He will only consider these iridium plugs so no other recomendations please. I know I saw an actual chart comparing these heat ranges somewhere between some major brands but I did a search and can't seem to find it anywhere. Thanks in advance. I have the basic 3.4 setup on the car with mods listed in sig....
  18. #18 Re: NGK spark plugs for stock
    No Iridium plugs for modded cars.
    They suck.
  19. #19 Re: NGK spark plugs for stock
  20. #20 Re: NGK spark plugs for stock
    Wausau, WI
    They suck.
    I agree... but not my choice anymore... I assume that the 55's would be the correct range( about a half range hotter) or the 6's would be a half range colder than the AL104's?
  1. spark plugs
    By silverstreak in forum General Tech Discussion
    Last Post: 08-01-2009, 06:09 PM
  2. spark plugs
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2009, 12:32 PM
  3. spark plugs
    By Nos shottss in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-12-2009, 09:34 PM
  4. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
  5. Spark Plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 10:45 PM
