Thread: CASE learn process
Results 1 to 5 of 5
  1. #1 CASE learn process
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    hello, ive been looking around at different aftermarket PCMs and have a question. intense racing states that all cars will benefit from a CASE learn. i was just wondering if this is required? will it cause your car to run better, or will it run fine without? or does it vary from car to car?? also could not having this done cause an SES light?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  2. #2 Re: CASE learn process
    Nov 2008
    Fremont Nebraska
    bump
  3. #3 Re: CASE learn process
    Donating Users
    Plainfield, IL
    some cars need a case learn after installing a pcm however some do not, it is reccommended tho....if you have an aeroforce gauge then you can do it with that if not you have to take it in to the dealer....
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  4. #4 Re: CASE learn process
    Nov 2008
    Fremont Nebraska
    if i have one of those cars that needs one, will my SES light come on? if not, how will i know my car is one of those?
  5. #5 Re: CASE learn process
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    You will throw a code and get the SES light, yes. Intense PCM's are notorious for doing it - it isn't necessarily a bad thing, and I honestly don't know what they do/change that is different from anyone else.
    As for how/where to get a case learn - either the dealership or anyone that has a TechII or a Snap-On scanner. What needs to be run? "DTC 1336 - Crankshaft Position (CKP) System Variation Not Learned".
    What does it do?
    The crankshaft position system variation learning feature is used to calculate reference period errors caused by slight tolerance variations in the crankshaft, the crankshaft balancer interupter rings, and the crankshaft sensor hall effect switches. The calculated error allows the PCM to accurately compensate for reference period variations. The crankshaft position system variation learning feature enhances the ability of the PCM to detect misfire events over a wide range of engine speed and load.
    The crankshaft position system variation values are stored in the PCM non-volatile memory after the crankshaft position system variationlearn procedure has been performed. DTC 1336 set indicates that the crankshaft position system variation values have not been stored in the PCM and the crankshaft position system variationlearn procedure must be performed. The learn procedure is required after the following service procedures have been performed, regardless of whether or not DTC P1336 is set:
    PCM replacement
    Engine replacement
    Crankshaft replacement
    Crankshaft balancer replacement
    Crankshaft position sensor replacement
    Any engine repair(s) which disturbs the crankshaft/harmonic balancer to crankshaft position sensor relationship.
    IMPORTANT: Be certain that they DO NOT select "REFLASH PCM" - if they do - you will have a stock PCM....again.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  1. CASE Learn in San Diego
    By jamster00 in forum West
    Last Post: 12-19-2012, 01:41 PM
  2. New PCM, :th_scratchhead:H CASE Learn???
    By 98GTPCALGARY in forum PCM Tuning
    Last Post: 05-06-2010, 09:53 PM
  3. Help!! Unable to CASE Learn
    By jamster00 in forum General Tech Discussion
    Last Post: 06-18-2009, 09:06 PM
  4. PCM and CASE Learn
    By High Rolling GTP in forum PCM Tuning
    Last Post: 06-09-2009, 06:36 AM
  5. Case learn done but PCM cannot be tuned. help!
    By Freebeer187 in forum General Tech Discussion
    Last Post: 02-05-2009, 03:54 PM
