Thread: Please Help!!! AC Issue
Results 1 to 13 of 13
  1. #1 Please Help!!! AC Issue
    VA
    I have a 2003 GP SE. The a/c is blowing cold through the third vent in the middle (towards the passenger side) and the vent on the passenger side, but the other three vents - two in the middle and on the driver's side - are not blowing cold. Any idea what this could be?
  2. #2 Re: Please Help!!! AC Issue
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Are they not blowing cold...or not blowing at all? If they aren't blowing at all - then you're issue is most likely a vacuum line issue.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  3. #3 Re: Please Help!!! AC Issue
    VA
    The vent on the passenger side and the right one of the middle vents on the dash do blow cold. The middle vent and the left vent on the dash and the driver's side vent do not blow cold.
  4. #4 Re: Please Help!!! AC Issue
    Quote Originally Posted by sb76 View Post
    So....they are blowing some air - just not cold? Correct?? One thing I forgot to ask - and I'm not sure - does your car have dual climate control?
    -Swash
  5. #5 Re: Please Help!!! AC Issue
    VA
    Yes, two vents are blowing cold, just not the ones on the driver's side. And yes, it has dual climate control.
  6. #6 Re: Please Help!!! AC Issue
    Perhaps I am not asking the question correctly. The vents that are not blowing cold air...are they blowing ANY air?? This makes a big difference in diagnosing your issue.
  7. #7 Re: Please Help!!! AC Issue
    VA
    Perhaps I'm not responding accordingly, sorry...yes, they are blowing air, just not cold.
  8. #8 Re: Please Help!!! AC Issue
    You need to check all of the vacuum lines on the back of the HVAC controller in your dash. You should not have any outlets that don't have a vacuum line attached to them. If all of that checks out ok - then you likely have a damper issue.
    -Swash
  9. #9 Re: Please Help!!! AC Issue
    VA
    Thanks for your help!
  10. #10 Re: Please Help!!! AC Issue
    VA
    Where is the damper and how do I get to it??
  11. #11 Re: Please Help!!! AC Issue
    GTP Level Member SuperSport's Avatar
    Michigan
    From what Ive read, warm drivers side vents signify low refrigerant. Again, Ive read this multiple times, dont know if its true or not...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  12. #12 Re: Please Help!!! AC Issue
    GT Level Member skidoojames151's Avatar
    seattle
    yea definately is true...i had the same problem and so i charged it up and now both sides are cold...really cold now
  13. #13 Re: Please Help!!! AC Issue
    Michigan
    Youre lucky. The shop told me my AC is plugged and only takes 7oz of refrigerant. Neither side is cold at all..
  1. another kr issue
    Last Post: 02-24-2009, 12:30 PM
  2. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  3. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
  4. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
  5. PM Issue
    By 04DetroitLS in forum Forum Bugs/Suggestions
    Last Post: 05-16-2008, 07:39 AM
