Thread: can you convert you car to onstar and adding the temp mirror?
Results 1 to 16 of 16
  1. #1 can you convert you car to onstar and adding the temp mirror?
    SE Level Member Roanokegprix's Avatar
    Roanoke Va
    just wondering if anyone has done it and what will be needed, thanks
  2. #2 Re: can you convert you car to onstar and adding the temp mirror?
    Wausau, WI
    I have no idea, but I would like to have the temp/thermometer auto dimming mirror as well
  3. #3 Re: can you convert you car to onstar and adding the temp mirror?
    Lakeside, TX
    It just so happens I am doing just that.
    All I have so far is a plan, but I believe it's sufficient to work.
    So first, I have a 2005 year model Grand Prix GTP, which I learned was originally a rental vehicle, so naturally there are no extra options besides the supercharged engine... no OnStar, no uplevel DIC, no TAP Shift, etc. Your vehicle must be 2004 or newer. 2003 and earlier used analog technology, which will not work now, and to the best of my knowledge, 2004+ OnStar equipment is incompatible with 2003 or earlier Grand Prix'.
    OnStar helped me tremendously in my 2007 Saturn Ion when this chick t-boned it. You know how it works I'm sure so I won't go into details. Naturally I want it again.
    There are several components hidden here and there to make OnStar work. Here's a quick list:
    1) Mirror
    2) Vehicle Communication Interface Module
    3) GPS Antenna
    4) Cellular Antenna
    5) Sensors in the front doors, front, and rear to detect collisions
    You have many obstacles before you. The first of which is this. GM says in the Service Manual:
    "Important
    The vehicle communication interface module (VCIM) has a specific set of unique numbers that tie the module to each vehicle. These numbers, the 10-digit station identification and the 11-digit electronic serial number, are used by the National Cellular Network and OnStarĀ® to identify the specific vehicle. Because these numbers are tied to the vehicle identification number of the vehicle, you must never exchange these parts with those of another vehicle."
    I think they'll let you do it. Maybe with some minor lying.
    Now obviously there's the mirror. Grand Prix OnStar Mirrors were the type with three buttons and integrated microphone. Grand Prix never had an option for compass and/or temp in the mirror, so if you want it there, you'll be doing some intricate modifications (beyond what you've got to do already.) If you want compass and temp, look at the how-to's here for how to upgrade your DIC to the uplevel 5-button version, and this will add temp and compass there. Auto-dimming mirrors are another story.. you may find a compatible auto-dimming mirror without compass and temperature that is compatible. There are many many versions of the mirrors.
    Next, you'll need the the Vehicle Communication Interface Module (VCIM). This is the core of the OnStar system, containing cellular and GPS electronics. It is located behind the radio under the IP. Three bolt holes are present where you can install it.
    You'll need the antenna(s). Antennas of the time had cellular and XM capability in the same package (I think). Not totally sure b/c I opted to get the brand new "sharkfin" antenna. It has GPS, XM, and Cellular antennae all integrated and looks sexy. But if you go with the factory setup, the Grand Prix had a compass module and GPS antenna mounted to the rear package shelf (where the rear speakers are,) and the cellular antenna mounted on the roof almost right above the mirror (prior to '05, comes with complimentary roof leaks,) or above the back seat ('06 onward). You can put it where you like really.
    The collision sensors are the same ones used to deploy the airbags I think. So if you have side curtain airbags, you should have the side sensors. Everyone has the front sensor, and I don't know about the rear one.
    That's as far as I've gotten.
    There are numerous wiring considerations, and schematics will likely be necessary to connect everything. I hope to find a salvage vehicle to tear apart and get the original harnesses, or at least see how it's connected.
    I have the GM Service manuals through 2005, so if it changed significantly afterward, I don't know it. One thing I know about Gen 5 OnStar in the Grand Prix is that communications are Class 2 Serial, whereas other vehicles often used GMLAN instead. I wonder if the Grand Prix electronics were ever upgraded to GMLAN communications standards before its discontinuance...
    This is the skeletal information. I'd be happy to give you access to my Service Manual (it's online) if you like. It has detailed procedures, pinouts on the component connectors, rudimentary component location diagrams, plus all sorts of other information you might like to know.
    Last edited by derek3073; 07-16-2009 at 04:54 PM. Reason: Remembered something! lol
  4. #4 Re: can you convert you car to onstar and adding the temp mirror?
    Charles City, IA
    GM dropped the coverage for the 97-03 grand prixs. So you would have to get the newer digital stuff. Also you could get a compass and temp in the mirror on the 97-30 grand prixs.
    SMGPFC Two Nipple General
  5. #5 Re: can you convert you car to onstar and adding the temp mirror?
    SLP, GTP or call it MUT! thunder71173's Avatar
    West Frankfort Illinois
    I just got one of these mirrors out of a 40th anny gtp does anyone have any idea how I wire it? It has a 16 pin plug on the back. I know the onstar wont work but the compass and auto dim would be nice
  6. #6 Re: can you convert you car to onstar and adding the temp mirror?
    Reynosa,Mexico
    Well I also wanted Dimming and compass on my mirror don't really care about the temp since it's already on the a/c unit display so I went and got a rear view mirror of a Lincoln LS already has the compass sensor attached to it just have to feed it 12v to get it to work easy as pie, well more like koolaid, pie is to hard.
  7. #7 Re: can you convert you car to onstar and adding the temp mirror?
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    they ended the service on all onstar equiped cars that were manufactured before 03 so..
  8. #8 Re: can you convert you car to onstar and adding the temp mirror?
    Apr 2011
    Stevens Point, WI
    If you really want on Star, wouldn't it be easier to just go aftermarket?
    CES: OnStar expands to aftermarket - CES 2011 CNET Blogs
  9. #9 Re: can you convert you car to onstar and adding the temp mirror?
    I dont want onstar the mirror I just got has it on it all I want to work is the compass temp and auto dim
  10. #10 Re: can you convert you car to onstar and adding the temp mirror?
    GT Level Member RotyP's Avatar
    Tn
    Sir, our sensors indicate you are in a junkyard.
    2007 Grand Prix GT - 20% Tint, Red Inlays
  11. #11 Re: can you convert you car to onstar and adding the temp mirror?
    lolol yep I found an un molested 40th anniversary in pull apart heaven
  12. #12 Re: can you convert you car to onstar and adding the temp mirror?
    SE Level Member 02 35thLE's Avatar
    ankeny ia
    It's easy to add the compass/temp mirror. Just drop down the overhead console and there is a harness up there that plugs into the mirror. Plug that into the mirror and the compass and auto dim will work. To get the temp to work there is a 3 wire connector with 2 wires in it near the battery that you can hook up the temp sensor to. I have done this to 2 different GP's now. Both of them have been 02's but they should all be the same just check for the harness in the overhead console.
  13. #13 Re: can you convert you car to onstar and adding the temp mirror?
    This mirror has 1 16 pin harness
  14. #14 Re: can you convert you car to onstar and adding the temp mirror?
    May 2011
    Florida
    You said the harness is right under the overhead console? I have an 02 with a sunroof, is the connector hard to find or plugged into anything? I did find the temp. connector under the hood but can't find the one behind the overhead console...
  15. #15 Re: can you convert you car to onstar and adding the temp mirror?
    Donating Users Slappyn's Avatar
    Dec 2012
    Goldsboro, NC
    Quote Originally Posted by darock1427 View Post
    Did anyone have any luck with this. I just found an onstar mirror but am not sure how to wire it up (on star services excluded of course).
  16. #16 Re: can you convert you car to onstar and adding the temp mirror?
    Sep 2011
    Copperas Cove, TEXAS
    There are write ups in the how to section on putting different mirrors in older cars, just have to search the how to section.
  1. adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 04-19-2010, 07:10 PM
  2. Mirror Temp reading SC
    By Hamm61 in forum Audio, Security & Visual Electronics
    Last Post: 05-18-2009, 08:42 PM
  3. OnStar
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2009, 05:11 PM
  4. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  5. questions regarding adding an aftermaket cd player to bose/onstar
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 04:34 AM
