Thread: Noisy blower motor (HVAC fan )
Results 1 to 3 of 3
  1. #1 Noisy blower motor (HVAC fan )
    Fuquay-Varina, NC
    Hello all ! New to this forum , Im a regular over at LS1tech . I just bought a 1997 GTP for the wife and it has the Dual climate control option . When you turn on the fan ( or AC or Heat ) the fan is so loud you cant hear yourself think ! I mean it is LOUD and will vibrate the dash and your feet !
    Sooo , does anyone know where the blower motor is for these cars ? I checked inside the engine compartment and didnt see it where I normally would suspect it would be. Is it under the dash in the passenger compartment ? How hard is it to replace the blower motor ?
    Thanks in advance for any info you can give !
    - Joe
  2. #2 Re: Noisy blower motor (HVAC fan )
    SE Level Member tpalmer's Avatar
    Florida
    it's located behind the glove box. Remove the passenger side kick panel under the dash. Once you do this you will be able to see the blower motor, its held in by 3 bolts.
    http://www.cardomain.com/ride/3307755
    ZZP 1.0 PCM | HV3 Insert | ZZP High Velocity Throttle Body | K&N FIPK Air Intake Kit | 2.5" DP | 2.5" Magnaflow Catback Exhaust | 180* T-Stat
  3. #3 Re: Noisy blower motor (HVAC fan )
    Fuquay-Varina, NC
    Thanks for the info ! Woot ! Sounds like an EASY fix !
  1. blower motor
    By Chleby in forum General Tech Discussion
    Last Post: 09-13-2017, 04:00 PM
  2. Another Blower Motor Question.
    By darylward in forum General Tech Discussion
    Last Post: 09-11-2009, 04:24 AM
  3. Blower motor runs but no/little air comes out.
    By bradford82 in forum General Tech Discussion
    Last Post: 01-13-2009, 05:58 PM
  4. Blower Motor?
    By TheOtherNick in forum General Tech Discussion
    Last Post: 11-18-2008, 12:09 AM
  5. HVAC Blower Question
    By 2001camaroB4C in forum General Tech Discussion
    Last Post: 10-25-2008, 02:05 AM
