Thread: Cutting fuel lines
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Cutting fuel lines
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by agrazela View Post
    It is entirely possible to mod a stock L67 rail for a topswap so as to mate up to L36 lines (and make room for an IC) without any twisting / kinking / bending / modification on the lines:
    hmm, I don't know, I think I liked all of the fittings better.
    2001 Buick Regal LS - Almost Stock
  2. #22 Re: Cutting fuel lines
    Feb 2008
    San Diego, CA
    Ha ha, yes I was sporting this for awhile:
    But me no trusty cheapo brass single-ferrule compression fittings.
    Steel swagelok-style dual-ferrule fittings would be better, but also bulky and very expensive, even for knock-off brands.
    Brazed tubing extensions = clean, cheap, and reliable.
  3. #23 Re: Cutting fuel lines
    QCA, IA
    I was talking more about this :
    I was planning on doing something more like your second version, but sounds like that's not a good idea?
  4. #24 Re: Cutting fuel lines
    Banned - Busted For Scamming
    Feb 2009
    do fuel rails, coming out with them.
  5. #25 Re: Cutting fuel lines
    Feb 2008
    San Diego, CA
    Quote Originally Posted by Scimmia View Post
    Oh yeah, that piece 'o bling was just a proto-prototype to get the angles and routing right before cutting and bending tubing; never installed and run in that configuration.
    Even my second version with only two fittings had two issues:
    1) Under WOT pressure, the fitting on the feed line would weep gas ever so slightly.
    2) That long, extended, return bend line was so heavy the whole return line was starting to sag/bend under the weight.
    The first issue could probably be solved with Swagelok, but not the second. Further, to mod that rail for an IC would have required at least 4 more Swagelok fittings, now we're talking some money.
    The third version uses a brazing technique to extend the steel lines. Working out great so far.
    But unless the OP is interested in keeping his stock lines and is looking for a cheap top-swap fuel rail solution, I think I'm helping to take this thread off-topic.
  6. #26 Re: Cutting fuel lines
    Barksdale AFB, LA
    Anyone have part numbers for the fittings to adapt from the AN line to the fuel rail? I had them in my cart at Summit and then they went and changed their website and it dumped my cart.
    2009 Subaru Impreza WRX STI
  7. #27 Re: Cutting fuel lines
    Feb 2009
    are you more interested in keeping the modded rails or the ones me and parker are coming out with?
  8. #28 Re: Cutting fuel lines
    TDCRacing
    Guest
    I think he's going to stick with the modded.
    What brand do you perfer and I will look them up for you.
  9. #29 Re: Cutting fuel lines
    Feb 2009
    is he looking for an to npt?
  10. #30 Re: Cutting fuel lines
    TDCRacing
    Guest
    An to tube.
  11. #31 Re: Cutting fuel lines
    Barksdale AFB, LA
    Unless yours are cheaper than $150, I'm sticking with modded. I don't care about looks, only functionality.
  12. #32 Re: Cutting fuel lines
    Feb 2009
    sorry, but the materials alone cost more then that, otherwise i would hook it up.
  13. #33 Re: Cutting fuel lines
    Barksdale AFB, LA
    I understand, hence why I'm going with modded rails.
    So, anyone have those part numbers for adapting to the stock rail fittings? I thought they were in the How-to thread, but I looked and couldn't find the part numbers.
  14. #34 Re: Cutting fuel lines
    Barksdale AFB, LA
    For others' reference, they're Russell fittings. Part numbers 640850 and 640860.
  1. SS fuel Lines
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2008, 01:02 AM
  2. ses codes and car cutting out
    By Xhondaguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2008, 12:33 PM
  3. Car Cutting out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-31-2008, 04:48 PM
