Thread: overheating
Results 1 to 4 of 4
  1. #1 overheating
    montreal
    Hi, the gtp I've spotted would come for cheap, but it overheats on short/medium trips, coolant is new and the T-sats as well.What ciould be the issue? Gasket?water pump? rad? I could pay 600$ for the car and fix it, but I hope it doesn't cost too much.
  2. #2 Re: overheating
    TDCRacing
    Guest
    The only things it could be is the following.....
    Water pump,Radiatior clogged,Electric fans,Wiring issue for the electric fans.
    Sounds like a good deal to me.
  3. #3 Re: overheating
    tj
    forgot about the radiator cap
  4. #4 Re: overheating
    Jul 2008
    Poteau Oklahoma
    you could have the coolant system flushed for good measure. after I saw what syn pulled outta his it convinced me to flush mine, and it has helped alot. if your getting it cheap enough you could also replace the coolant temp sensor.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  1. Engine keeps overheating
    By bigpapa53023 in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-30-2009, 07:05 PM
  2. overheating issue
    By doc7000 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 01:18 AM
  3. HELP!! overheating
    By sciontc1011 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:55 PM
  4. overheating problem
    By knightriider in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-24-2008, 03:54 PM
  5. overheating
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-09-2008, 10:18 PM
