OK my very first post on here...where to start...
I've been dealing with an electrical gremlin for some time now. I finally got myself a nice multimeter so I could find the source of my parasitic drain. With everything shut off I was pulling 90mA so I started pulling fuses. I finally found the culprit at #29 under the hood which is only marked 'Radio (10)'. Well when I started up my car with this fuse pulled not only did I not have radio but I also had no dash CPU, no ABS and no TCS so it's quite apparent that fuse controls much more than just the radio as it lists.
What I need is a wiring schematic that covers the fuse box under the hood, and specifically the #29 Radio (10) fuse so that I can figure out everything that is being run under this one fuse and how to disconnect each accessory individually to isolate my parasitic draw. When I pulled that fuse the meter dropped from .090 amps to .002 amps so I know it's something on that circuit. Thanks in advance.
