Thread: Last minute tips/tricks/suggestions?
Results 1 to 19 of 19
  1. #1 Last minute tips/tricks/suggestions?
    Jersey
    As some of you know im getting ready to top-swap, I have everything i need besides some stupid small stuff. Im not going to lie, This is my first project that's this big, so i have some small noobish questions. I understand how to do everything and have been reading a lot. Anyone have any trick or tips on anything im going to come across that haven't been discussed
    some small tips i have gathered
    -pour oil into lifter valley to clean out coolant, if it spilled
    -using copper rtv spray, spray both sides of head gaskets
    -dab of rtv on each corner of the orange lim gaskets
    -un-clip coil pack wire harness and crank engine to get oil on parts before starting
    -sc gasket can be installed dry
    feel free to correct anything that i mentioned
    some Q's that i can think of...
    what types of rtv am i going to need?
    do the head bolts need rtv or can they be installed dry?
    when pouring oil into lifter valley, do i need to remove the lifters first?
    do the cylinders really have to be TDC when installing my roller rockers?
    any advise will be greatly appreciated
    16' wrx sti- stock
  2. #2 Re: Last minute tips/tricks/suggestions?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by 99prixgt View Post
    I would unplug the injectors instead of the ICM to get everything oiled up. I'd rather not be spraying a bunch of fuel into the cylinders, all it could so is cause wash down, and expel a bunch of unburnt fuel out your exhaust.
    I use Ultra Black RTV for most things, unless it's on something that's going to get really hot, then I'll go to copper.
    New GM head bolts (you do have new ones, right?) come with sealant on them already. If you're going to studs, you need some thread sealant on them.
    No need to remove the lifters, they're constantly bathed in oil anyway.
    The valves need to be closed when you install the rocker, and having the piston at TDC does that for you.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Last minute tips/tricks/suggestions?
    Jersey
    thank you
    and yes i have new felpro head gasket bolts. As far as the roller rockers go, how does that work? because on my rebuilt heads the valves are already closed. Am i going to want to get piston #1 TDC and then do the rest by firing order?
    16' wrx sti- stock
  4. #4 Re: Last minute tips/tricks/suggestions?
    Donating Users blowfishRus6's Avatar
    g.a.
    fyi, i dident turn mine to tdc. dont know what it matters but mine are fine.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  5. #5 Re: Last minute tips/tricks/suggestions?
    Banned - Busted For Scamming
    Feb 2009
    unplugging the ignition module cuts spark AND fuel, so no need to unplug the injectors. for an accurate torque you do need to have each one at tdc, i know its a pita, but do it right. easiest thing to do for coolant drain is to take out the front knock sensor, its the block drain. you will most likely have NO coolant to worry about, if so maybe a drop or two, nothing like if you didnt use it. put a dab of rtv and i mean a dab onto the end of the threads of the lim bolts, some see oil/coolant, just extra insurance. other then that, take ur time and it will go smoothly except that one or two exhaust manifold bolts that want to be stubborn. maybe later you can buy one of my intercoolers
  6. #6 Re: Last minute tips/tricks/suggestions?
    QCA, IA
    thank you
    They're going to be closed with the rocker off, of course, but what about when you go to put the rocker on? If the cam is in a position where it wants the valve open, it will start to open the valve as you tighten down the rocker. This will screw up your torque reading.
  7. #7 Re: Last minute tips/tricks/suggestions?
    Jersey
    ahh i see how that works now, thank you everyone! and yes intercooler is on my list for later . Anyone have any tip on getting the harmonic balancer bolt out? Ive been impacting it for about an hour and it won't budge. Is my impact gun big enough? its a 120psi gun. I used penetrating oil too. Ive heard of people using a torch but that kind of worries my since my oil pan gasket is leaking and there is some coolant around, plus i don't see how that works because if you heat up the bolt it-self it will only expand.
    16' wrx sti- stock
  8. #8 Re: Last minute tips/tricks/suggestions?
    get a better impact. mine at home wouldnt do it, but when my brother (mechanic) brought his nice one home it came right off.
    either that or figure out a way to get a big ass breaker bar on there. do you have the flexplate locked with a vice grips?
  9. #9 Re: Last minute tips/tricks/suggestions?
    Barksdale AFB, LA
    Oh, it will spill... Lots and lots of coolant, lol.
    If you got the OEM replacements from Felpro, don't! Felpro says not to spray them. I didn't and they're just fine. They're fiber gaskets and they're meant to go on dry. You're supposed to spray metal gaskets, not fiber gaskets. Just make sure you scrape the gasket surfaces on the block real well.
    Yep. Both above and below the joint.
    If you want to unplug the fuel pump, go for it. But like Scimmia said you don't want it squirting fuel in without burning it. I didn't even bother and it was fine.
    Umm... yep. Not sure what you'd coat it with.
    My first time doing intake gaskets I used normal RTV. This time I got high temp copper RTV since I was doing exhaust work too that required RTV.
    If they're OEM style bolts, they have everything on them they need already. Install as is. Make sure to follow the proper torquing procedures.
    No.
    Just need the valves to be closed otherwise they may come loose over time. The way I did it was to tighten all the rockers down and go ahead and torque them to spec. At this point you can see which rockers in that bank are in the open position. I made note of them and turned the crank until they were closed, then hit them again with the torque wrench to be sure they were at the right value.
    2009 Subaru Impreza WRX STI
  10. #10 Re: Last minute tips/tricks/suggestions?
    Feb 2009
    yea, dont spray the gaskets, the felpros work fine and especially if you clean the surfaces good then use brake clean.... all grease off there will give you a good seal. two times detonated and didnt blow the gasket
  11. #11 Re: Last minute tips/tricks/suggestions?
    Jersey
    I bought felpro head gaskets for the L36. They work right? The gtp ones were way to expensive.
    16' wrx sti- stock
  12. #12 Re: Last minute tips/tricks/suggestions?
    l36 felpro gaskets work. put them on dry. did you buy head studs? those would be a fantastic investment for you..
  13. #13 Re: Last minute tips/tricks/suggestions?
    Jersey
    I didn't get head studs. I got the felpro head bolts. I figured ill get the studs when i do ported heads.
    16' wrx sti- stock
  14. #14 Re: Last minute tips/tricks/suggestions?
    QCA, IA
    see, that's why studs would have been smart. You pay once, and keep reusing them, so if you're planning on taking the heads off again for ported heads, paying for the bolts is just money down the drain.
  15. #15 Re: Last minute tips/tricks/suggestions?
    Jersey
    ^true statement. Ported heads won't be for a while though, at least until i get a job lol
    16' wrx sti- stock
  16. #16 Re: Last minute tips/tricks/suggestions?
    i bought them when i did my top swap, they are GREAT. resuing them once pays for themselves already in not having to buy another set of bolts.
  17. #17 Re: Last minute tips/tricks/suggestions?
    Barksdale AFB, LA
    I didn't really care about head studs when I was installing. I'm not planning on pulling the heads again on this engine for a long time, if ever. Some say it makes installing easier, but the pegs on the block made lining everything up cake. I didn't want to bother with teflon paste or any of that mess, and I knew the OEM bolts just seal up like they should.
    I haven't regretted it so far.
  18. #18 Re: Last minute tips/tricks/suggestions?
    yeah, that was the only problem with studs. i had a hard time sealing them at first. i had a slow seeping leak for a little while, never got into the oil or anything. i sealed them up well when i had my heads off the last time and it has been fine since.
  19. #19 Re: Last minute tips/tricks/suggestions?
    Charles City, IA
    You can also hold the gas pedal all the way down when cranking and it should cut the fuel.
    SMGPFC Two Nipple General
  1. Thanks. Any suggestions?????
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 01:26 PM
  2. N/A suggestions
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2009, 11:38 AM
  3. Last minute weekend trip?
    By BabyBlue in forum Midwest
    Last Post: 05-09-2008, 03:56 PM
  4. 5 Minute Management Trainning
    By webracin in forum Off Topic Discussion
    Last Post: 02-15-2008, 02:33 AM
  5. MOD suggestions please
    By scoobyydooooooo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 07:59 PM
