Thread: Likely cause of high LTFT's
Results 1 to 7 of 7
  1. #1 Likely cause of high LTFT's
    SE Level Member jims05ss's Avatar
    Lately I've noticed on my aeroforce that my LTFT's are about 6-7 at cruise (~75) on the highway and then when I let off the throttle for a few secs they tend to peg at about 15, neither of which, obviously is good.
    I have a couple ideas what may be causing this but I'll just play completely dumb (not that big of a challenge for me) and ask for other's ideas as to what may be happening.
    A few weeks ago I installed 1.9 rockers and with getting all the crap out of the way to get the valve covers off and then back on I wonder if I cracked or loosened a vac line or something.
    Probably as a direct result of this issue my time at the track this past weekend was about 6/10th's of a sec slower with my new rockers than it was last fall w/o them, 14.4 vs 13.8!
    05 Impala SS; 13.84 @ 100. SSIC, 3.25 pulley, 1.9's, PRJ tuned PCM, ZZP SS P-log, ZZP SS 3" DP, ZZP TB spacer, 4" FWI w/9" K&N, U-bend & resonator delete, Magnaflow cat, wrapped crossover, 180 t-stat, PRJ Wires, 103's, Royal Purple, Eibachs, front & rear STB's, Aeroforce.
  2. #2 Re: Likely cause of high LTFT's
    +16.4 LTFT = vacuum leak.
    with a vacuum leak youre probably running lean and knocking.
  3. #3 Re: Likely cause of high LTFT's
    Yeah, that's what I'm guessing but if the leak isn't on my SSIC/blower assembly (hasn't been anyway since PRJ installed it a year ago), what are the usual suspect things/areas?
    Car isn't really knocking much though, maybe momentary 1-2 @ WOT but 0 under heavy accelleration.
  4. #4 Re: Likely cause of high LTFT's
    who knows..just get a can of carb spray and spray around the motor. if the idle changes and revs up then you have found the leak.
  5. #5 Re: Likely cause of high LTFT's
    Try the typical T-Fittings...they always seem to be going bad due to dry rot. Also check your HVAC lines and TB Fittngs to see if those might be cracked...
  6. #6 Re: Likely cause of high LTFT's
    Barksdale AFB, LA
    He has no HVAC lines, but TB fitting is a good thing to try too.
    2009 Subaru Impreza WRX STI
  7. #7 Re: Likely cause of high LTFT's
    Thanks for the suggestions everyone; I'm gonna grab some spray and check everything I can think of one day real soon, probably this weekend.
  1. How High Is To High?
    By samsquanch in forum General Tech Discussion
    Last Post: 06-17-2009, 12:29 AM
  2. Hid with a high beam
    By crywolf in forum Visual/Body Modifications
    Last Post: 01-27-2009, 07:13 PM
  3. Increased LTFT's?
    By jims05ss in forum General Tech Discussion
    Last Post: 12-17-2008, 07:49 PM
  4. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
  5. Tuning LTFT's
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-10-2008, 08:37 PM
