Thread: Pulley making metal grinding noise??
Results 1 to 11 of 11
  1. #1 Pulley making metal grinding noise??
    SE Level Member abuckley1290's Avatar
    Jul 2008
    This has been going on for a while now and it got profoundly louder today. It sounds like metal on metal grinding. I looked down and the noise is clearly coming from the A/C compressor pulley. Do i need a whole new compressor? or can i just replace the pulley assembly? Thankyou
    40th Anniversary GP
  2. #2 Re: Pulley making metal grinding noise??
    TDCRacing
    Guest
    Well it's more than likley the bearings in the compressor that is making the noise.
  3. #3 Re: Pulley making metal grinding noise??
    Jul 2008
    So would it be possible to remove the compressor then replace just the bearings ?
    40th Anniversary GP
  4. #4 Re: Pulley making metal grinding noise??
    TDCRacing
    Guest
    I'm sure you can service the compressor. But i'm sure some special tools will be required.
    I have a compressor that's used and in good shape. If you're intrested let me know.
  5. #5 Re: Pulley making metal grinding noise??
    Banned - Busted For Scamming
    Feb 2009
    mine has been making a whining sound for a while, goes away when you turn on a/c, its the a/c compressor bearings. You need to go to autozone and get two rental tools, One is a holder device and the other is a puller/installer tool. Once you take off the clutch, the bearing is right there, its like $30 at autozone or advance auto parts.
    Logan
  6. #6 Re: Pulley making metal grinding noise??
    Jul 2008
    Logan
    thanks man i think ill go this route...which exact holder and puller would i need? Thanks again
    40th Anniversary GP
  7. #7 Re: Pulley making metal grinding noise??
    Feb 2009
  8. #8 Re: Pulley making metal grinding noise??
    Jul 2010
    Michigan
    I'm having the same issue but the pulley tool fits into the threads, but not between my wheel well and the unit. What can I do?
  9. #9 Re: Pulley making metal grinding noise??
    Feb 2010
    indiana
    Drop the RF of the cradle.
  10. #10 Re: Pulley making metal grinding noise??
    Jul 2010
    Michigan
    So we've managed to get the clutch and everything off, but now we're having an issue getting it back on. The pulley needs to go on about 1/8 inch further but no matter what, we can't seem to get it go to on further to be in line with the rest of the pulleys on that belt. The porcelain piece is touching the block, but I don't remember what angle the electronic plug was at when we took it off. Any help would be greatly appreciated; I haven't driven in 3 days.
  11. #11 Re: Pulley making metal grinding noise??
    SE Level Member xsvtank's Avatar
    NJ
    it could also be the coupler
  1. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
  2. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
  3. bad grinding sound
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2009, 04:53 PM
  4. Brakes making noise.
    By TDCRacing in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2008, 10:03 AM
  5. Grinding from right side front plus more
    By 99BluGP in forum Brakes/Suspension/Chassis
    Last Post: 06-11-2008, 10:15 AM
