Thread: change map light bulb?
Results 1 to 3 of 3
  1. #1 change map light bulb?
    SE Level Member basshead42's Avatar
    Toledo, OH
    Anybody knowhow to change the map light bulb? I wanna change it to LEDs but when i try to mess with it, it feels like i'm gona break it.
  2. #2 Re: change map light bulb?
    GT Level Member Preotic's Avatar
    Missoula, MT
    if you pry the map light down a little bit you can get a look at how it is held in there and then you won't feel like you're gonna break it. I think there are two clips on the front that you can see when you pry it down a little bit.
    I found these pic(97-03 of course)
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  3. #3 Re: change map light bulb?
    TDCRacing
    Guest
    Quote Originally Posted by basshead42 View Post
    Although this turned into an informational thread be sure you're posting in the correct section that way you get a quicker response.
  1. What bulb is...
    By vdpd2005 in forum General Tech Discussion
    Last Post: 12-08-2009, 04:01 PM
  2. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  3. change oil soon light
    By adamlesandrini in forum General Tech Discussion
    Last Post: 03-25-2009, 04:42 PM
  4. light bulb
    By Myprixxx in forum Audio, Security & Visual Electronics
    Last Post: 03-01-2009, 06:18 PM
  5. performance shift light bulb
    By prostreet in forum Off Topic Discussion
    Last Post: 03-12-2008, 09:29 PM
