Thread: 5.7 Engine swap..
Results 1 to 16 of 16
  1. #1 5.7 Engine swap..
    monroe,wi
    So i am wondering, if you can put a 5.3 in a 1997-2003 grand prix.. Can you put an aluminum block 5.7 in there??? I would imagine you could use the 5.3 transmission, wire harness, possible computer too??? but not sure anyone have any ideas or thoughts?? I just love the way V8's sound compared to anything else.
  2. #2 Re: 5.7 Engine swap..
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    i dont see why not, computer for the 5.3 wont work though, are you thinking LS2?
    the bellhousing should be the same, I dont see any issues but the computer.
  3. #3 Re: 5.7 Engine swap..
    Aug 2008
    Long Island, New York
    wow that would be sick...
  4. #4 Re: 5.7 Engine swap..
    monroe,wi
    ls2? Why wouldnt the computer work? Couldnt you just tune it for more gas? i am really considering seeing if it works, and a supercharger too lol. It would be pretty sick!!
  5. #5 Re: 5.7 Engine swap..
  6. #6 Re: 5.7 Engine swap..
    GT Level Member 04BlackComp_G's Avatar
    Apr 2008
    Rockport, ME
    I thought about doing the LS4 in mine but that would be too much of a pain in the butt when it comes to the pcm. That would make one hell of a sleeper though.
  7. #7 Re: 5.7 Engine swap..
    Apr 2009
    CT
    well being that the grand prix is a front wheel drive vehicle and the LS2 is predominantly rear wheel, good luck with that. There is a guy over on LS1tech who is swapping in an LS2, IIRC, into a 308 and I believe he was creating a custom bell housing in order to use the 4T65. Not much progress has come along since last year tho.
    Like GTP 98 said tho, your best bet would be to do an LS4 swap, especially being that the 05-08 Grand Prix had them as an option.
  8. #8 Re: 5.7 Engine swap..
    Aug 2008
    60118 NE Illinois
    the 5.7 and 5.3 dimensions on the block are the same. the bellhousing bolt pattern should be the same with all of their 90 degree small blocks
    you can prolly tune the ls4 cpu to work with the 5.7. but in missouri there is a late model junk yard, mainly sports cars, over 500 ls motors at at that place. He sells the engines, harness and cpu together.
  9. #9 Re: 5.7 Engine swap..
    Aug 2008
    all i know is its gonna be one hell of a job if you do it... best of luck
  10. #10 Re: 5.7 Engine swap..
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    Quote Originally Posted by Ragefear View Post
    Not to veer of topic, but a 308, as in a ferrari 308? thats worth checking out.
    Engineering the impossible.
  11. #11 Re: 5.7 Engine swap..
    Aug 2008
    60118 NE Illinois
    ^^prolly a 302 bored .30 over.
  12. #12 Re: 5.7 Engine swap..
    Apr 2009
    CT
    lol, yes, as in ferrari 308. I just found it again...
    EPP Ferrari 308 LS2 project car! - LS1TECH
  13. #13 Re: 5.7 Engine swap..
    Oct 2008
    mascoutah, Il
    I have seen someone do the swap somewhere on the web, ls1 into 97-03 using alot of gxp parts anyway. I'll try to dig it up.
    EDIT:
    Not the site I originally found but his post on clubgp should suffice,
    http://www.clubgp.com/newforum/tm.as...Check=42485991
    2002 GTP
    custom HOK paint
  14. #14 Re: 5.7 Engine swap..
    Barksdale AFB, LA
    Before the LS4 GM put a LS1 into an Impala as a concept. They had to shave the crank, modify all the accessories, create a custom water pump, and make an adapter plate for the bell housing. Here's the article:
    LS-1 Powered Impala SS - Feature - GM High-Tech Performance
    2009 Subaru Impreza WRX STI
  15. #15 Re: 5.7 Engine swap..
    Apr 2008
    Rockport, ME
    Here is the swap that I found the made me want a v-8 in mine. Check it out!
    Tom K of Texas is the proud owne
  16. #16 Re: 5.7 Engine swap..
    Quote Originally Posted by Sabrewings View Post
    Hot Damn I'd drive that
  1. Engine Swap
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 04-04-2009, 09:56 AM
  2. L36 engine swap
    By themagicdustman in forum General Tech Discussion
    Last Post: 02-05-2009, 07:08 AM
  3. engine swap question!!!!
    By 98bdgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2008, 12:27 PM
  4. Engine swap
    By BankRupt in forum Off Topic Discussion
    Last Post: 07-19-2008, 11:06 AM
  5. engine swap
    By 3800John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2008, 02:53 PM
