Thread: WTF?! Rear hubs
Results 1 to 7 of 7
  1. #1 WTF?! Rear hubs
    Nov 2008
    Chicago
    How do I get the rear hubs off? I undid the three or four bolts through holes but its still on there solid as a rock! I need to put longer wheel studs on (they are too long to do without taking it off).
  2. #2 Re: WTF?! Rear hubs
    Nov 2008
    Chicago
    bump-bah-da-bump
  3. #3 Re: WTF?! Rear hubs
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The answer to all of life's problems, the BFH.
    It's just rusted in there.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: WTF?! Rear hubs
    Nov 2008
    Chicago
    I wedged a chisel in behind the backing plate with a BFH, tried banging on the backing plate, the thing is solid as a rock.
  5. #5 Re: WTF?! Rear hubs
    QCA, IA
    I just looked it up to make sure I wasn't missing a step, and it's pretty straight forward. Remove the caliper with bracket, remove the rotor, disconnect the wheel speed sensor, remove the 4 bolts, and pull the hub out. Has to be rust, gotta love midwest winters.
  6. #6 Re: WTF?! Rear hubs
    Nov 2008
    Chicago
    Time to get a compresser and beat that sucker with the air chisel! Thanks for the help!
  7. #7 Re: WTF?! Rear hubs
    Feb 2008
    You might just try a large 3-jaw gear-puller. That's how I got my front one off the very first time I did a hub change.
  1. How to replace front hubs
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 03-12-2015, 11:18 AM
  2. Rear STB only...
    By a3gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2009, 06:17 PM
  3. Axles, hubs and Halos - oh my!
    By MnRedGP in forum General Tech Discussion
    Last Post: 02-08-2009, 02:08 PM
  4. Wheel Bearings/Hubs
    By bcrosby51 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:49 PM
  5. Rear O2
    By probuilder1 in forum General Tech Discussion
    Last Post: 07-27-2008, 10:12 PM
