I bought some Halo headlights on Ebay and they installed painlessly but they shake alot when I am driving...anything I can do to stop that?
yes they shake like a girl with big cans running, there are a couple of right ups on clubgp but i dont think theyre worth it, black ebay lights and HID's are the way to go
i had the same problem when i put them on a car for a friend of mine. if you can find a thick insulating tape like what you would use to seal a door were its like a layer of soft foam, make sure its thick. take out the light and put the tape on the bottomwhen you put it back together it should be more solid. if it still happens you didnt use thick enough insulation.
The lights bouncing is a common issue with the headlights. There is a write up to limit the amount of bouncing. Some people have said it works and others say it limited the bouncing. As stated weather stripping works as well.
ClubGP Message Forum troubleshooting
I also wrapped some electrical tape around the long tab on the projector bracket. That helped a little.
