Thread: the engin recall
Results 1 to 17 of 17
  1. #1 the engin recall
    SE Level Member toffog87 gtp's Avatar
    Jan 2009
    normal IL
    sooi started up my 02 grand prix and was letting it warm up a little bit. when i noticed that my fog light hid was out well i started to mess with that and i noticed that my engin smelled funny i looked and it appers that its leaking oil on the exaust manafold. i know thats not normal but any help as to why that is and how serious it is?????
    joe
    ps my spelling is really bad sorry!
  2. #2 Re: the engin recall
    GT Level Member black98gt's Avatar
    Rochester NY
    Did you get the valve cover recall done?
  3. #3 Re: the engin recall
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to Tech section.
    Valve cover gasket needs replaced.
  4. #4 Re: the engin recall
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    All Grand Prix's leak oil man.......
    A front valve cover is pretty easy to do....
  5. #5 Re: the engin recall
    Aug 2008
    Long Island, New York
    is that what this recall is? just the valve cover gasket? if it s then i gotta fix that asap
  6. #6 Re: the engin recall
    Nov 2008
    Chicago
    its a free fix obviously. mine was leaking too before i brought it in
  7. #7 Re: the engin recall
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    you just bring it to the dealer and it gets done?
  8. #8 Re: the engin recall
    Barksdale AFB, LA
    It only applies to 97-03 GTPs. No recalls for non-GTPs yet.
    2009 Subaru Impreza WRX STI
  9. #9 Re: the engin recall
    Jan 2009
    normal IL
    yep got it fixt and it works great thanks guys
  10. #10 Re: the engin recall
    Columbus, OH
    I know it's abit late to be posting in this particular thread, but does anyone know if there is a cut-off date or mileage for service recalls? I just bought my 1999 Grand Prix GTP ,the prior owner tells me he has done none of the service recalls..
    Thanks for any responses!
  11. #11 Re: the engin recall
    SE Level Member singularity's Avatar
    Houston, Tx
    from what i understand, once a service recall is made, it is valid, until the problem has been fixed..
    On my old 91 nissan 240sx, i got brand new automatic seatbelts in 2008 because of a recall.
    Im not sure how pontiac does it, if you have to recieve the recall notice before they will preform the work, or if they simply run the vin to see whats been done or not.
  12. #12 Re: the engin recall
    Wausau, WI
    I would also like to know as my gaskets are leaking as well.........was the recall for the front valve cover only or for both?
  13. #13 Re: the engin recall
    Charles City, IA
    I am pretty sure they will only do the front. I think you can get gm to pay you to do it your self or at least they should give u some gaskets. Try to hit them up for both gaskets and do it your self and save them the labor. I am pretty sure they would do it.
    SMGPFC Two Nipple General
  14. #14 Re: the engin recall
    GT Level Member CMURDAx's Avatar
    Toledo, Ohio
    the recall is for GT's also. i just had mine done a week nd a half ago
  15. #15 Re: the engin recall
    Charles City, IA
    Thought they just pull out the spark plug channel on the gt's?
  16. #16 Re: the engin recall
    SE Level Member bigdawg15005's Avatar
    pittsburgh,pa
    Quote Originally Posted by Sabrewings View Post
    Actually theres 1 for both. just call any pontiack (gm) dealer and give them the vin they will tell u if theres a recall on it.
  17. #17 Re: the engin recall
    Wausau, WI
    for gtp owners........it is recall 7035 and it is for the front one only. There should be no restraints on this due to age or mileage and yes they can look it up via the VIN #.
  1. Recall done and now wtf...
    By the1euge in forum General Tech Discussion
    Last Post: 10-25-2008, 05:36 PM
  2. Recall
    By crshoveride in forum General Tech Discussion
    Last Post: 08-01-2008, 01:46 PM
  3. My GTP is getting the recall done
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2008, 11:41 AM
  4. ? on recall
    By mlambert in forum Off Topic Discussion
    Last Post: 06-20-2008, 02:58 PM
  5. Recall
    By GTPluv in forum Off Topic Discussion
    Last Post: 04-04-2008, 11:10 AM
