Thread: pace setters
Results 1 to 20 of 28
  1. #1 pace setters
    Donating Users
    Plainfield, IL
    if im on a budget are these good headers? can i get away with non coated? and i heard the Y leaks but will good clamping and a shyt load of rtv fix that? lemme know because im ordering them soon....
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: pace setters
    TDCRacing
    Guest
    Pacesetters are ok if you don't mind leaks. There good headers except where the y- pipe connects together. You'll need different clamps for sure.
  3. #3 Re: pace setters
    Donating Users
    Plainfield, IL
    will the clamps fix my prob and am i better off going 1 5/8 primaries if i only plan to mildly mod
  4. #4 Re: pace setters
    TDCRacing
    Guest
    Quote Originally Posted by iamwhutiam003 View Post
    The clamps will help. But they did not fix my problem. Yeah I think they do make a bigger 1 3/4 size now huh? You'll be fine with the smaller ones.
  5. #5 Re: pace setters
  6. #6 Re: pace setters
    Jersey
    There is nothing wrong with the pacesetter's. Primary size is up to you. Get some new clamps from Sinister Drag Designs - Chicagolands new performance specialist! these clamps were designed to fix all the comon problems with the headers sealing properly (Im not sure if they have clamps available for both 1-3/4 and 1-5/8's though)
    16' wrx sti- stock
  7. #7 Re: pace setters
    Nov 2008
    Chicago
    ZZP also sells an install kit where they modified the header tube to fix the issue
  8. #8 Re: pace setters
    Donating Users
    Plainfield, IL
    so yes get them if i dont get coated will they look like shyt after a short amount of time i was just gonna wrap em or paint them?
  9. #9 Re: pace setters
    SE Level Member blown98gtp's Avatar
    Feb 2009
    iowa
    Has anyone tried expanding the pipes that go into the Y to make a better fit?
    98 gtp:L36/GenV/S1X/Pacesetters/FWI/Intense tune/timing commander/104s/P&P heads/DevilsOwn alky kit/ZEX dry shot/42.5#/shift kit/ScanGauge
  10. #10 Re: pace setters
    Barksdale AFB, LA
    Quote Originally Posted by blown98gtp View Post
    ZZP does that if you buy it from them.
    2009 Subaru Impreza WRX STI
  11. #11 Re: pace setters
    TDCRacing
    Guest
    I got it done at the local muffler shop for free. But it still dod not help me much.
  12. #12 Re: pace setters
    Donating Users
    Plainfield, IL
    i found a deal they are 2000 deg ceramic coated and have the zzp pro kit with 1000 miles on them for 350....then ill just get SDD clamps and gaskets...you think ill be happy they are 1 3/4 primaries but ive heard gtps shouldnt have a rpoblem running these over 1 5/8 thats its more the N/A motors that need to be careful right?
  13. #13 Re: pace setters
    TDCRacing
    Guest
    FWIW you can go to napa or most anywhere local and just asked for a stepped band clamp. You need one that measures 2/ 1/2 on one end and 3'' on the other.
  14. #14 Re: pace setters
    Donating Users
    Plainfield, IL
    thanks for the info man ill prob do that its cheaper right? hey im tkaing your dp out tomm morning to ship it you by the way!
  15. #15 Re: pace setters
    Donating Users
    Plainfield, IL
    you guys think i can run a 3.3 pulley with a pcm and colder stat? or should i just throw a 3.4 since the headers will prob let me safely run a 3.5 or 3.4.....
  16. #16 Re: pace setters
    Aug 2008
    Long Island, New York
    you could get away with a 3.4 probably... just make sure you scan
  17. #17 Re: pace setters
    TDCRacing
    Guest
    They were like 11.00 each at napa i think. Stainless.
  18. #18 Re: pace setters
    TDCRacing
    Guest
    Scan
  19. #19 Re: pace setters
    Donating Users
    Plainfield, IL
    ok then the aeroforce shall tell my fate i think im gonna go modular and just get a 3.4 and then i can drop later...
  20. #20 Re: pace setters
    Donating Users blowfishRus6's Avatar
    g.a.
    man car does just fine with the large primaries. no coated my paint melted INSTANTLY. you might wanna go with coated. i think there great headers for the price and with the clamps.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. real gtp pace car 4 sale!
    By boosting98 in forum Off Topic Discussion
    Last Post: 10-17-2008, 10:47 PM
  2. Calling all W-body Pace Cars!!
    By Gearhead43 in forum Off Topic Discussion
    Last Post: 01-10-2008, 08:11 PM
