Thread: Got pictures for my vacuum line where does it go
Results 1 to 10 of 10
  1. #1 Got pictures for my vacuum line where does it go
    Dec 2008
    Florida
    Where does this vacuum line go? It is the middle on on the T that wraps around the engine bay towards the battery. Here are some pictures.
    vacuum line GTP pics pictures from cars photos on webshots
    Thanks
    2000 Pontiac Grand Prix GTP
    I love my 5.0, but a little civilized muscle is a good thing! Especially when it always runs and doesn't leave you stranded on the highway.....
  2. #2 Re: Got pictures for my vacuum line where does it go
    Dec 2008
    Florida
    A member told me something about this line, but my question is where do I attach it? Thanks for any and all help
  3. #3 Re: Got pictures for my vacuum line where does it go
    May 2008
    staten island,NY
    that is so your HVAC will work, i would fix that asap, it goes down the firewall to inside the car
  4. #4 Re: Got pictures for my vacuum line where does it go
    Dec 2008
    Florida
    anybody have a picture of where it goes into or comes out of the firewall?
  5. #5 Re: Got pictures for my vacuum line where does it go
    Feb 2008
    It goes through the firewall with the rest of the wires from the fuse block. It's near the bottom of the firewall on the passenger side. You can see it fairly easily from below the car if necessary.
  6. #6 Re: Got pictures for my vacuum line where does it go
    Dec 2008
    Florida
    ok thanks Ill try and figure out what it connects onto now that i know where it leads. Im probably going to have to end up running a new wire.
  7. #7 Re: Got pictures for my vacuum line where does it go
    Feb 2008
    The line you are holding in the pictures runs into a check valve with 2 outlets right behind the battery on the front side of the fender well. At the split, one line runs along side the wires coming out of the fuse block and into the cabin to the heater controls and the other around the nose of the car and to a vacuum reservoir behind the driver's side fog light. At least that how it is on my '97. Since it's newer, yours may only run through a check valve and directly to the heater controls. I modified mine to work in that way since the line that ran around to the reservoir was split and I didn't feel like running fresh line all the way over there.
  8. #8 Re: Got pictures for my vacuum line where does it go
    Barksdale AFB, LA
    It should still have a vacuum canister if the HVAC is vacuum operated. That way you can operate the HVAC while under boost.
    2009 Subaru Impreza WRX STI
  9. #9 Re: Got pictures for my vacuum line where does it go
    Feb 2008
    Operating the HVAC while under boost..... That just sounds like trouble. I suppose what I did can be considered a safety feature?
  10. #10 Re: Got pictures for my vacuum line where does it go
    Dec 2008
    Florida
    Ok thanks for all the help guys. This gives me everything i need to know
  1. Vacuum line...where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 02-25-2009, 11:15 PM
  2. Vacuum line for Fuel Press Regulator, where does it go?
    By 97grandprix38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2008, 12:17 AM
  3. vacuum leak
    By boredout in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-15-2008, 08:22 AM
  4. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
