Thread: Srage 3 Phenolic cracked......????
Results 1 to 13 of 13
  1. #1 Srage 3 Phenolic cracked......????
    SE Level Member GINOSGTP's Avatar
    Feb 2009
    Ontario Canada
    hey just noticed my syage 3 intercooler has some cracks in it......will it seal or is it a goner?
  2. #2 Re: Srage 3 Phenolic cracked......????
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    All stage 3 intercoolers are going to fail at some point and time. So its probley best to get something differnt, you will have to do this now or latter.
    When you stick 2 materials with different expansion property and try to seal them together you will have problems. I am sure most of them are "user install errors" It was a good idea for a product but who ever did it did not have an engineering background.
    My EX wifes other car is a broom.
  3. #3 Re: Srage 3 Phenolic cracked......????
    they should have made the entire thing phenolic, not half of it.
  4. #4 Re: Srage 3 Phenolic cracked......????
    Feb 2009
    Ontario Canada
    so can i still use it or am i screwed????? Do you think ican fix it in any way......anyone have any ideas?
  5. #5 Cracked Phenolic............HELP!!!!!
    Feb 2009
    Ontario Canada
    Can i still use a cracked STAGE 3 INTERCOOLER CORE????? if i cant is there anyway to strengthen the pheonolic side of the core ??????
  6. #6 Re: Cracked Phenolic............HELP!!!!!
    TDCRacing
    Guest
    Where is it cracked at?
  7. #7 Re: Srage 3 Phenolic cracked......????
    merged both of your threads since they are on the same subject.
    small crack, big crack does not matter. the parts design is flawed and its just going to get worse.
    Do you want to risk messing up your engine? If no then junk the ic.
  8. #8 Re: Srage 3 Phenolic cracked......????
    TDCRacing
    Guest
    Wow they made half of it phenolic?? Another faulty product by ZZP!
  9. #9 Re: Srage 3 Phenolic cracked......????
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by TDCRacing View Post
    I don't think they made a core of half metal/half phenolic. THe core was half made of ultem, not phenolic. All of zzps new stg 3 cores are made of all phenolic...
    They say when the ultem shows signs of cracking that its just cosmetic, just keep an eye on it and if anything take it off and inspect it a little better.
  10. #10 Re: Srage 3 Phenolic cracked......????
    i thought half of the core was aluminum and the other was not?
  11. #11 Re: Srage 3 Phenolic cracked......????
    Feb 2009
    Ontario Canada
    i will post pics and show where the cracks are just have to take pics first....
  12. #12 Re: Srage 3 Phenolic cracked......????
    Feb 2009
    Ontario Canada
    never mind thankks for all the help......i decided that i am goin to try and repair the cracks.....i will take pics and post to show everyone.....thnks for all the help
  13. #13 Re: Srage 3 Phenolic cracked......????
    Jan 1970
    Maquoketa, Iowa
    All of ZZP's new stage 3's are made of phenolic, both halves. Before that they had half aluminum and half ultem. The ultem kept on cracking and zoomer said it was from incorrect install/torquing and damage was only cosmetic. Believe what you want but I didnt see anyone prove that it was causing a leak, so he might actually be right.
    This is the typical cracking of the ultem:
  1. Phenolic Throttle Body Spacer [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 09-27-2008, 03:21 PM
  2. Phenolic Throttle Body Spacer
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2008, 01:12 PM
  3. Cracked windshield
    By wayne1981 in forum Visual/Body Modifications
    Last Post: 12-16-2007, 10:42 AM
