Thread: Fuel Pump Problem
Results 1 to 6 of 6
  1. #1 Fuel Pump Problem
    Forest Lake, MN
    I've got a 99 Grand Prix 3800 series II supercharged. Think I might have a bad fuel pump - not so sure. I noticed the problem when I went to start the other night. Turns over, but gets no gas. I noticed I didn't hear the usual hum of the fuel pump kicking in. However, there is no voltage at the pump when ignition is on. The fuel pump fuse is good - tried swapping the two fuel pump relays in the fuse box - thinking one was bad - no dice. Thinking maybe the fuel pump resistor, but there doesn't seem to be any power at the harness to the resistor. I know it wouldn't be hot, but thought you could jump across the two wires to get a result. I would suspect the fuel pump, but since there isn't power to that, I question my original diagnosis. Not sure what to do at this point - any suggestions? I don't want to start buying unnecessary parts and doing unrelated repairs. I considered the MAF or maybe that Fuel Pump resistor, but I've done some reading on the forum and don't have exactly the same symptoms. Any help would be appreciated.
  2. #2 Re: Fuel Pump Problem
    I live here. UR LOSN's Avatar
    Rockford, IL
    Moved to Correct section.
  3. #3 Re: Fuel Pump Problem
    TDCRacing
    Guest
    Try bending pin 85 on the relay over. This will bypass the resistor. If it's a bad resistor you will know by doing this.
  4. #4 Re: Fuel Pump Problem
    Forest Lake, MN
    Oddly enough - the car started this morning - I could hear the fuel pump engage, but this afternoon would not start - same symptoms again. I'll try the resistor solution and let you know what happens..... Thanks!
  5. #5 Re: Fuel Pump Problem
    Moore, Oklahoma
    Sounds like a resistor problem to me, i'd definatly check that out...
    Shawn W. Larsen
  6. #6 Re: Fuel Pump Problem
    Apr 2009
    Springfield, Mo
    ok so im having the same problem. but mine was running just fine and now wont. have no fuel. i bent pin #85 over and still nothing. i have a VERY dim light (test light) at the fuel pump (low voltage) im assuming! does this mean the fuel pump itself is bad? i have already replaced both relays! and where is the resistor located?
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Help! fuel pump?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2009, 11:50 AM
  3. Bad Fuel Pump
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2008, 11:52 PM
  4. Fuel pump??
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-01-2008, 03:25 AM
  5. fuel pump or FPR? or both?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2008, 03:43 PM
