Thread: loud tapping noise
Results 1 to 13 of 13
  1. #1 loud tapping noise
    SE Level Member blown98gtp's Avatar
    Feb 2009
    iowa
    My engine's making a loud tapping noise that I can't figure out. I was out on the highway doing a couple high speed blasts. On the way back home, I noticed the noise, which changes according to engine speed. It seems to be coming from the passenger front of the engine. I've taken both valve covers off and checked the rockers, springs, and pushrods. Looked good. Took the front cover off, chain, dampner, and gears looked good. Did a cylinder leadown test and all cylinders tested good. Oil pressure never dropped. No codes. The harmonic balancer is not cracked. I took the inspection cover off and checked out the flexplate while turning the engine by hand, saw no cracks. Drained the oil, no metal. Removed both belts and the noise is still there. I'm stumped. I thought if it was a lifter there would be a loose rocker arm/pushrod. I thought if it was a rod bearing oil pressure would drop. I took a video with my phone, but I'm having problems posting it. Thanks for any help/advice.
    98 gtp:L36/GenV/S1X/Pacesetters/FWI/Intense tune/timing commander/104s/P&P heads/DevilsOwn alky kit/ZEX dry shot/42.5#/shift kit/ScanGauge
  2. #2 Re: loud tapping noise
    TDCRacing
    Guest
    I am going to say you have a tapping lifter.
  3. #3 Re: loud tapping noise
    Feb 2009
    iowa
    decided I would take the intake off and check the lifters. When I pulled the fuel rail off on the #1 injector I found a piece of plastic that had broken off from a electrical connector(the tab) wedged in between the injector and the head, blocking the injector. So that cylinder was obviously running way lean. What could have happened that could make the motor make this noise? Obviously if the cylinder was lean it could overheat ruining a piston, but wouldn't that have showed up on my cylinder leakdown test? I think I'll put the fuel rail back on and fire it back up to see if the noise is still there. If it is, I'm thinking engine teardown time.
  4. #4 Re: loud tapping noise
    Barksdale AFB, LA
    How did it get in between the injector and the head? I would've figured you would've had a vacuum leak from that.
    2009 Subaru Impreza WRX STI
  5. #5 Re: loud tapping noise
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    Seems like it.
    I'm pretty sure it is going to end up being a lifter. Especially if it is light tick and not a knock.
  6. #6 Re: loud tapping noise
    Feb 2009
    iowa
    Earlier in the day, I had pulled the fuel rail off, the piece of plastic had broken off of the connector and fell down into the injector boss. I did not see it when I put the fuel rail back on, and when I pushed the injectors into place it just wedged itself in between the injector and the head. When I took the fuel rail off, the o-ring was tore, so I don't know how it wasn't spraying fuel all over. By the way, I put the fuel rail back on and the noise is still there.
  7. #7 Re: loud tapping noise
    Feb 2009
    iowa
    I hope it's just a lifter, but this is a loud tapping noise. Lifters that I've heard before are more of a ticking noise. Bearings are more of a knock.
  8. #8 Re: loud tapping noise
    Feb 2008
    see if you can get that sound bite up!
  9. #9 Re: loud tapping noise
    Feb 2009
    iowa
  10. #10 Re: loud tapping noise
    TDCRacing
    Guest
    That sounds more like a knock than a tick. That is definetly not a lifter. More than likley a rod. So I change my statement.
    Rod knock.
  11. #11 Re: loud tapping noise
    could also be a cracked/worn exhaust manifold gasket.
  12. #12 Re: loud tapping noise
    TDCRacing
    Guest
    Not making that kind of noise.
  13. #13 Re: loud tapping noise
    Feb 2009
    iowa
    pulled the motor today. found this upon inspection. #1 rod bearings are wiped. However, they rod journals and crank surface don't look bad. I'll measure with micrometer, but I'm thinking I could get away with new bearings and recondition the rods. On the other hand, I was thinking of finding a L36 to swap out the bottom end for higher compression. What do you guys think?
    http://i285.photobucket.com/albums/l...gtp/rod007.jpg
    http://i285.photobucket.com/albums/l...gtp/rod008.jpg
    http://i285.photobucket.com/albums/l...gtp/rod009.jpg
    http://i285.photobucket.com/albums/l...gtp/rod005.jpg
    http://i285.photobucket.com/albums/l...gtp/rod003.jpg
  1. Loud whistling noise
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 09:04 PM
  2. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
  3. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  4. Loud noise above 45mph
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 11-09-2008, 10:03 PM
  5. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
