ne 1 else having or had issues with their windows rolling down?
Mine roll down just fine, but are quite slow to roll back up. 12-year old window motors might be to blame here, though. This question would better be placed in the tech section, where it will probably get more responses. Post up what specific problems you're having with the windows.
Welcome, by the way. You ought to do an introduction in the "Introductions" section.
Moved yet another thread...
Had problems getting them to go down and then on others going up. Fixed them all myself.
Window motors on GPs go out all the time I think. Mine went out a couple years ago and I didn't replace it for a year. When I did, they put in a used one so it's really slow going up. Replacing my battery helped some, but if the car is off, forget rolling it up...
There's a writeup on how to fix the window problem but you will need to take the panel off to see if the motor is out or the cable is snapped or if one of the plastic guides is broke and the cable came off the regulator. If you can take off the panel and see what the problem is we can talk you through the fix and you can get the parts from Ed Morad for a reasonable price.
