Thread: p1133 ?? what is this code
Results 1 to 11 of 11
  1. #1 p1133 ?? what is this code
    SE Level Member 1bad3800's Avatar
    Jan 2009
    bensalem pa
    p1133 ?? what is this code and how do i fix it and what causes this ?? the car is 2002 gtp and it ha pacesetters on it so... the extion is brand new and the o2 is brand new and it is a bosh sensor any ideas any on and on the laptop at 30% throttle it dumps fule ???
  2. #2 Re: p1133 ?? what is this code
    TDCRacing
    Guest
    It's an o2 sensor code. You mentioned you hade pacesetters. So you more than likley have burnt wires associated with that o2 sensor.Wich would be the front one.
  3. #3 Re: p1133 ?? what is this code
    Jan 2009
    bensalem pa
    nope the extion has been changed along with a brand new sensor
  4. #4 Re: p1133 ?? what is this code
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    i just ran through this same thing.....use a denso, they are better than a bosch.(i know, i refunded many when i worked for advance auto parts) denso is more accurate. i read up and searched them before i bought it and i am sold on them now..
  5. #5 Re: p1133 ?? what is this code
    TDCRacing
    Guest
    Quote Originally Posted by 1bad3800 View Post
    Well you have something wrong. Either a bad sensor or soldier connections that were not done right or other types of connections that have come loose.
    The two brown wire's are for the heating element. And they have no polarity. Be sure you match the wires up correctly. It is a pain in the but. I did it also with a bosh sensor.
  6. #6 Re: p1133 ?? what is this code
    TDCRacing
    Guest
    Quote Originally Posted by badbrad View Post
    I'll also agree. Like mentioned above I used a bosh for a while and had no problems. But did end up returning it and replacing it with a Denso. Even got it shipped to me and was way cheaper than any o2 that I could pick up locally.
    I bout the denso from rock auto.
  7. #7 Re: p1133 ?? what is this code
    GTP Level Member Scimmia's Avatar
    QCA, IA
    This is not at all uncommon with Bosch O2 sensors. There have been countless reports over the years on these forums of virtually new Bosch sensors throwing this code. Get a Denso or Delco and call it a day.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: p1133 ?? what is this code
    TDCRacing
    Guest
    I also heard about this. And it was a slow switching code that they were throwing.
  9. #9 Re: p1133 ?? what is this code
    Dec 2008
    hueytown, alabama
    the bosch sensors in my camaro are thowing codes.... i got the denso from ebay for 33 or $34 shipped. much cheaper than with my advance discount..one tuner on 3800 pro was a big beleiver i n them......good luck dude................ps always use the direct plug in type, i'm in electronics in school(biomed) and the splicing of the wires does affect the readings and voltage....my $.02
  10. #10 Re: p1133 ?? what is this code
    Jan 2009
    bensalem pa
    whelll thank you for the responces but i think it narrows down 2 bed motor mounts because the wide ban is reading good except at 30% throttle so.. that is the y pipe i here a slight leak i am thing it could be that i have new zzp poly mounts odered dose any one know any about them i know about viberation i am not worrired about that how is drive ability?? and launching from a lite?
  11. #11 Re: p1133 ?? what is this code
    Buffalo
    Edit wrong thread
  1. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  2. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
  3. Anyone know a paint code?
    By Reptile in forum Off Topic Discussion
    Last Post: 08-12-2008, 03:30 PM
  4. P1133 Engine not running smooth?????
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2008, 12:23 PM
  5. paint code
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 04-13-2008, 08:41 PM
